Old 25th April 2012, 11:40 AM
GlynH GlynH is offline
Default D3 Error codes
I have the following codes recurring after a clear down and although I know which component is reporting a fault I wondered if someone else could give me a steer o just what the problem might be please?
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H07 0160
Revision: 01604507 Serial number: AUX3Z0E5368773
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8BB41E96B08CA9
Part No: 4E0 905 852 E
Component: ELV 1940
4E0905852E ELV 1940
1 Fault Found:
00192 - Left Rear Door Handle Touch Sensor (G417)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 118
Mileage: 204144 km
Time Indication: 0
Date: 2012.04.24
Time: 17:58:48
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P0002S4Q
Coding: 0430707
Shop #: WSC 02313 785 00200
VCID: 2759B21596F6351
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 1
Mileage: 204147 km
Time Indication: 0
Date: 2012.04.24
Time: 17:57:26
Thanks & kind regards,
-=Glyn=-
Old 25th April 2012, 11:58 AM
Dodgy auto door lock/unlock button, not too expensive to fix. I'd be concerned about the airbag igniter though.
Old 25th April 2012, 01:44 PM
+1 for door lock button.
Airbag igniter faults are usually bad connection in wiring connectors. Self test uses very low voltage to test igniter resistance and if the connection is bad low voltage does not pass through bad connection. Side passenger airbag would be the one in passenger seat. Seat airbags are the most common for giving faults as wiring gets disturbed by moving seat. Disconnect battery, wait for 15-20 min, check wiring, unplug and plug in connectors a couple of times, make sure everything is plugged in securely. Reconnect battery, delete error codes and see if it returns. DO NOT try to test igniter resistance with multimeter or similar as it could set airbag off.
Old 6th May 2012, 10:45 PM
Thanks for the tips...looking back over Service History it seems like the airbag has been a problem for the last couple of years
The Left Rear Door Handle Touch Sensor was cleared bit has now manifested into a rear heater sensor or something now?
EML came on Thursdy, cleared errors on Friday but back again today
-=Glyn=-
Old 6th May 2012, 10:52 PM
Rear footwell heaters are the most common fault I've seen on D3 with 4-zone climate... Probably just crap components.
Old 7th May 2012, 08:02 AM
Just what/where are these footwell sensors exactly...in the footwell I guess?
Are they easy to replace and does anyone have the part number/price please?
-=Glyn=-
Old 7th May 2012, 08:34 AM
47p2's Avatar
47p2 47p2 is offline
It is a small heating element which allows the rear passengers to adjust the temperature irrespective of what the front temperature is set to. i.e. if the front is at 18c and rear passenger requires 20c then the heater will provide extra warmth at the rear. When they are not working (which as Richard says is very common) the rear passengers can only adjust the temperature upwards to whatever the front is set at, but they can adjust the temperature downwards.
The link is for a Phaeton but from my research it is a similar system to the A8
Scroll to page 28
Nite Blue 3.0L SE Quattro
Old 7th May 2012, 11:34 AM
Aah...thanks for that.
Not exactly the most important piece of kit in the car then?
-=Glyn=-
