Old 30th January 2013, 10:07 AM
Default Indicator bulbs for red lenses
Guys
After searching for ages, I've finally found a source of green, BA15s 21W bulbs for use in the rear indicator if you've got red lenses (US lenses or otherwise modified).
https://www.sip-scootershop.com/main...ut/Basket.aspx
I've checked that the green bulbs do, indeed, flash amber in a red lens but, up to now, I've only used a 10W bulb which is a bit dim! I put these in for my MOT and swapped back to clear 21W bulbs for daily use.
The only snag is that I need to order at least 10 bulbs to meet the minimum order. They're £2.32 each (plus around £4 or so for P&P).
I'm going to order 10 anyway (even though I really only want 4/6), so let me know ASAP if you'd like any.
Old 30th January 2013, 10:41 AM
I'll have 4 off you Jim
Old 30th January 2013, 10:43 AM
Do you know if anyone else has the red lenses?
Old 30th January 2013, 10:44 AM
I think Amar does on BAJ1T
Old 30th January 2013, 10:52 AM
Sent a PM
Old 30th January 2013, 11:03 AM
To me or Amar? I dont have one!!
Old 30th January 2013, 11:06 AM
To Amar!
Old 30th January 2013, 11:27 AM
sloss's Avatar
sloss sloss is offline
He's not very bright for an artitekt......
Old 30th January 2013, 11:31 AM
think Oli has red ones too
Audi S8 2002, Black (even the chrome bits)
Audi RS6 Avant 2008, Daytona Grey
Maserati Granturismo 2008, Metallic Nero Carbonio
Old 30th January 2013, 01:24 PM
He does, Brian, youre right
