Old 8th August 2017, 05:28 PM
PH79 PH79 is offline
Default Rear door lock and outside handle replacement
Hello all.
Can someone please help me with inner panel removal, it seems to be mounted into the window frame. Any help would be highly valued.
I have the door card and inner panel removed to the window frame part. No ELSA available.
Thank you in advance
Old 9th August 2017, 09:52 AM
The attached 2 documents should help
Old 10th August 2017, 12:17 PM
Useful info indeed, thanks
I have now swapped the handle, but the old lock is impossible to get out without removing window frame completely.
The problem is that vcds reads left rear door is locked all the time while others read unlocked.
I tried to disable the safe motor with vcds, it didn't work either. Door still works normally.
I get this code on scan
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Any other ideas to get it working without removing the window frame?
