Old 28th May 2019, 10:12 AM
RS6's Avatar
RS6 RS6 is offline
Thankyou MikkiJayne sounds like a fun job for me hopefully it won't be too bad job!
i should of removed the aerial in hindsight haha
GPS survived they did have ago at it though!
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 28th May 2019, 10:21 AM
RS6's Avatar
RS6 RS6 is offline
The antenna is attached from inside the rear quarter. You'll need to remove the boot side trim to get to it, and iirc there's one bolt holding it to a bracket. It then drops down out of the rubber grommet - the force it needs can be quite scary as they're all pretty crusty by now. If it's stuck, tt helps to drop some lubricant (WD-40 etc) down between the aerial base and the gromment from outside, and then wiggle it around a bit to free it. The grommet is then just a push-fit in the panel.
There are a couple of versions of the aerial base depending on which options the car has (phone prep etc), and it has different connectors accordingly.
Does this look about right?
http://www.audipages.com/Tech_Articl...nnaremove.html
Old 28th May 2019, 12:27 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Aren’t these just for the phone prep?
I had one sitting in the cupboard that I gave to Jim last year.
2016 S5 Coupe Black Edition - Ibis White
Old 28th May 2019, 12:37 PM
That's what I thought too....
Isn't that just for the telephone?
And, depending on exactly what you've got in the car, probably won't connect to any current network.
Old 28th May 2019, 02:01 PM
GiffGaff(O2) work just fine in mine.
Old 28th May 2019, 03:06 PM
Same here. I use a Nokia 6310i in the cradle. Three no longer support the 6310i (not sure about the other providers) but Giffgaff still do
Old 28th May 2019, 09:00 PM
That procedure is about right but there is a plastic clip instead of a big nut. The black insert with the red o-ring is similar though.
Its used for the FM radio as well as the phone in cars with phone prep.
Old 29th May 2019, 09:37 AM
RS6's Avatar
RS6 RS6 is offline
this is the part number for the rubber base that pushes into the bodywork - 4a5035539
Got a new one today
Old 22nd August 2019, 08:28 PM
Audi Doody Audi Doody is offline
I have an electric ariel on my D2. How high should it go? Is there a way to take them apart to refurb them? My radio signal is not really that great, but the ariel does go high that i would have thought that it would be half decent.
Old 22nd August 2019, 09:13 PM
For which I still owe you a beer or two! Next meet perhaps?
