Old 5th June 2016, 12:34 PM
nakata nakata is offline
Default RNS-E and MFSW on D2
Did someone is done this retrofit RNS-E on four spoke MFSW?
Now A8 D3 4.2 40v Supercharged!!!
EX: A/S8 D2 4.2, moded done: Manual gearbox, Recaro seats, RNS-E + OEM Bluetooth with working MFSW, S8 converted engine, S8 susspension, Solar roof, RS6 brake setup and bigger servo and pump
Future mod: RS 4.2tt engine.
Old 5th June 2016, 04:02 PM
Our very own Notorious is running that configuration
Old 6th June 2016, 06:43 AM
No one is write DIY for this retrofit. I found correct J543(MFSW controller)
Just is need to wire up CAN signal to navi or cluster for infotainment.
* Just for prewired rns-d cars.
Old 6th June 2016, 05:30 PM
Well, found the correct controller from A6 C5. Prewired the CAN bus and now have working MFSW.
Old 6th June 2016, 07:42 PM
Retrofitted post-2010 RNS-E, MFSW and rear armrest with control buttons.
Here is the essential file:
http://www.motor-talk.de/forum/aktio...hmentId=695282
Old 7th June 2016, 08:38 AM
Good write up. Will easy for me if found it early.
But do it with other controller from A6 (with rns-d mk2).
