Old 29th March 2015, 03:27 PM
Conquistador's Avatar
Just picked the car up from being away for a few days having the wheels fully refurbished.
Before and after pics...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 29th March 2015, 05:17 PM
They did a nice job
Who did you use in the end?
Old 30th March 2015, 09:33 AM
Used http://www.paintituk.com/ - nice guys and very professional and helpful.
One of my centre caps is a bit manky so I'm trying to track one down to replace it.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 30th March 2015, 02:52 PM
Back on the subject of the interior trim, the pieces which are particularly bugging me to do at the moment are the small rectangle piece near the driver's side air vent and the long strip with 'quattro' badge running above the glovebox.
The following pages I've found are helpful to a point but I don't seem to have the middle bolt that it mentions which you can apparently only see half of so can't remove the air vents:
http://blog.ocarbon.com/2011/02/d2-a...removal-guide/
http://www.audipages.com/Tech_Articl...im_removal.pdf
Has anybody removed theirs or have any tips on how to remove them?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 30th March 2015, 03:25 PM
I think the retaining screw for the drivers side air vent is the one you get at up through the hole adjacent to the knee panel mounting clip. I know I accidentally undid mine as I had a "gap" there (no clip).
You can see the hole in the picture Jim posted for me in my "knee panel" thread.
I'll edit the link in here if I can find it...
Up above this hole! Get a small torch out to see what tool it needs (Torx T25 I suspect) http://forum.a8parts.co.uk/attachmen...0&d=1427555424
Old 10th April 2015, 11:16 PM
RanjS8 RanjS8 is offline
Default front trims
from memory which is a bit fuzzy so you have to forgive me.....i recall pulling out the driver side and passenger air vents.....once you pull them out, there are retaining screws or clips which you pull out and then the trims come off.
i did it on a pf a8 when i wrapped em in vinyl.....but it was about 4 years ago...hence the fuzzy memory.
Old 11th April 2015, 10:27 AM
Are you going to repaint the rest of your trims in aqua blue? shifter trim and the long dash strips.
I think it looks really good and goes perfectly with the cream leather.
Old 27th May 2015, 09:31 AM
Quick update.
Thanks to the help of Marcin and Scott at the weekend, the remaining trim pieces are now all done. I'm very pleased!
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th May 2015, 12:05 PM
wow !!!
this car should be given an award on our meet tomorrow
Old 27th May 2015, 12:10 PM
wow !!!
wow are you holding another meeting just tomorrow before our annual meet Sergey?
