Go Back   A8 Parts Forum > General Natter > Owners Meets
Owners Meets Any info for any meetings, events, track days
Old 5th June 2010, 06:33 PM
WOW, this looks like it will be a good meet. More people coming then the annual one
Old 6th June 2010, 09:30 PM
psychophil896
Guest
Posts: n/a
Thanks for the welcome, The Psycho bit comes from my drag racing days, 400bhp Minor with nitrous ,700bhp xr3i+.
My 3.7 sport has been off the road for about 8 months with a fuel delivery problem and no time to fix it as working on house, but i have done it now and have done away with the very over complicated in tank system.Hope to meet up with you guys soon,Phil
Old 7th June 2010, 09:48 AM
How do you work that one out as no one is coming yet. Are you coming to the annual meet?
Old 7th June 2010, 03:59 PM
What I meant to say was quite a bit more interest. I can't say for sure. I'm going to have to let you guys know maybe a week before if I do, will try though
Old 8th June 2010, 07:47 AM
Now that sounds very interesting. Do tell, with pictures if possible.
Old 8th June 2010, 05:33 PM
psychophil896
Guest
Posts: n/a
The Audi in tank system is simple/complicated????? I could not get any fuel up to the engine even after fitting new pump[ £132]. Looked at all the fuel pipes in the tank, in fact all the in tank system but could'nt find a fault.
Decided to remove all the pipe work, removed pump and cut all the plastic away just leaving the top housing [the bit you can see in the boot] extended the fuel pipe that bolts to the housing, refitted pump onto the end of the pipe and it now sits on the floor of the tank on the o/s, on the end of the pump i fitted a tee piece with a pipe going over to the other side of the tank n/s to collect the fuel, replaced the fuel senders in both sides, turned the key and bingo it runs sweet as a nut.. The only concern i had was what would happen when the n/s small part of the tank ran dry???? because the pump is covered in petrol continually it always has a constant supply of fuel and the fact that it may draw a little bit of air from the empty part of the tank has not been an issue as the car performs as before, i have put a few miles on the clock since this and all is well, so happy days Phil
Old 18th June 2010, 10:15 AM
I'll travel anywhere now I have joined the 50mpg+ club. I need to see some 8s as I miss mine soo much..!
Whats the latest?
Old 24th June 2010, 07:49 AM
Night Train's Avatar
I'll try to attend, although I can't guarantee anything on that, because things are quite busy this end.
Sorry I can't be more definite than that.
Looks like quite a number are intending attending the event, which is cool.
Other vehicles
Oh Yes....... The '98 PF S8!
Old 24th June 2010, 09:07 AM
KPS's Avatar
KPS KPS is offline
Hi,
I could try and attend, where would it be? I work mon-fri so only weekends but will confirm. Should be good though!
___________
Kunwar
2002 Audi S8
Old 24th June 2010, 11:07 AM
Hi all - quick update. . .
Looks like the first one may well be on a sunday afternoon, in the bristol area followed by the next one on a weds evening, perhaps more central like oxford or swindon/newbury/reading areas - we might even be able to invade one of mkoneman's weds evg summer dub club meets as an alternative to that one
Anyways i'm currently checking out venues to meet around the Bristol area and its likely the first one will be either the 18th or 25th July to fall in between the A8OC meeting and Audis in the Park
Tags
bristol, owners meet, sw meeting
