Old 2nd June 2020, 06:23 PM
Default Favour Needed From A D2 S8 Owner
Hi guys, my recently acquired S8 is missing both the S8 and Audi rings on the boot lid, I’ve now got them ready to stick on but want them positioned exactly as they were from factory.
Could one of you kind chaps please get me measurements for where they fit exactly on the rear boot lid? Also I’d like to know spaced out is the S and 8 is as the S & 8 come as individual units.
Thank You.
Old 2nd June 2020, 06:30 PM
Sorry, Amar, mine is in the body shop for a few weeks just now, but I’m sure someone will be along soon
Old 2nd June 2020, 06:34 PM
Thanks, Jim. I can’t wait a few weeks, it’s really bugging me it’s de-badged, so much so I’ve had to park it’s arse up against a wall and we all know the D2 has a great rear end so it’s a shame to hide it.
Hope nothing serious with your car Jim and it’s just some general TLC.
Old 2nd June 2020, 06:37 PM
I think one of mine still has the original badges on the boot. I can check tomorrow if no one else has measured one by then
Old 2nd June 2020, 06:39 PM
homer simpson's Avatar
I found the rings in the Tech Dump but no luck with the S8 badge
Old 2nd June 2020, 07:11 PM
Thank you, that’s perfect. I’ll get the rings on now and if anyone can help with the S8 badge that would be very much appreciated.
Old 2nd June 2020, 07:22 PM
Welcome back Amar.
Hmmmmm my S8 badge is a little misaligned.....
73mm, 40mm, 5mm seem to be the critical measurements.
(Photo to follow)
So that's 73mm from the bottom left corner of the badge to the edge of the boot lid.
And 40mm to the edge above the rear light (NOT to the light itself, there's a seal between)
And just 5mm between the two sections.
I suggest others take the same measurements…………..
Or are you trying to acquire the original PF version of the badge? (My old PF had those until it was stolen and accident damaged, the repairers binned them and fitted the newer type)
Old 2nd June 2020, 07:31 PM
Hi HP! I appreciate your help but yours doesn’t look right and is definitely a little off which will bug me.
Thank you all the same.
Old 2nd June 2020, 08:14 PM
How much better that does look!
ID:	23427   Click image for larger version
Old 2nd June 2020, 09:37 PM
Going in the right direction.
When you do find the correct badge location, please post here as I really do want mine to be correct.
PS: I found this online:
