Originally Posted by notorious
Camaro,
Audi OEM part numbers: 8D0941699B / 8D0941700B
Can be ordered from Valeo too. Part numbers: 087544 / 087545
These fog light come with H7 bulb and here's how they look like:
http://www.karosserieteileshop24.de/...01::60062.html
They were installed on late A8 D2s and A4 B5s.
I'm not sure, but maybe you'll have to buy new grills (non-split ones) and new lower bumper skirt if you want to retrofit them to older A8 D2. This need to be investigated with ETKA.
There's also Hella's kit on the market that should fit tip top. Hella is usually higher quality than Valeo, which Audi decided to use as OEM fog lamps supplier for D2 for some strange reason. Hella's part numbers: 1N0 010 845-011 / 1N0 010 845-021
Check out Hella catalog:
http://cat.hella.com/web/public/$configId/hella/$language/en/$country/GB/$showResult/0/$classification/100000/$category/101340/$catalogue/2/$objectType/PR/$object/1N0%2B010%2B845-011_289/$productCard/objectTypeParameters/index.xhtml
That is the lamp I have presently. We didn't get a projector, all fogs were reflector housing. I've decided to build a retrofit using a Ford Fusion lamp in the factory housing. I'm ordering them tonight. Here's some pics of the fog, its cutoff, etc.
Not my photos, just for reference.
