Engine mount (?) part number
Hi All
This is a photo of an engine mount (?) on my 2002 S8. It's at the front of the engine on the driver's side and is clearly in need of replacement! The photo is taken from the open bonnet. I have a little knock at slow speeds on rough road surfaces from around this area, so I suspect this might be the culprit. A proper description and part number would be most helpful. Thanks, Jim
4D0199267 'rubber mounting', about £50 iirc.
When you change it, remove some shims from underneath the body bracket so that the bracket sits neatly on the top of the mounting. The reason it fails is that from the factory the bracket is shimmed to the right height but after 15 years all the main engine mounts have sagged so the engine sits 3-4mm lower than when it was made and it tears this mounting in half. Put plenty of penetrating oil in to the mounting bracket threads from above a day before you start since the bracket collects water and the steel bolts go rusty. |
Thanks MJ.
Is it an easy DIY job to remove and replace it, or should I trundle down to my local Audi indy?
Its easy if you have the front end off. I would say the minimum dismantleage is undertray & bumper off and driver's side headlight out. You may need the front end in service position to get to the bracket bolts though.
Yep, a trip to my local Audi indy is due then. Thanks again. Wish we lived in the south-west!
Here is a couple of photos to give you a better view, when the front is off
Johannes _________ Audi S8 -99, Pearlescent, Alcantara/silk napa leather, Burr walnut insert, Alcantara roof lining upper pack A8 32V engine ----- Jeep Grand Cherokee -98 |
They're often stuck on to the bottom of the bracket with corrosion
With those shims/spacers, its almost as if Audi expected that torque mount separation to happen!
MJ, with the tensioner pads, are they doable en-situ, or do you need to remove the cam chain or inlet cam to replace them?
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived thanks to MJ Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
Both inlet cams have to come out, along with two of the cam caps on the exhaust. Right hand side you can do without disturbing the timing belt, but the left hand side sprocket has to come off to get the rear belt cover tinware off so you can remove the tensioner.
