Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Trims
D4 - Interior Trims Seats, dashboards, plastics, everything inside the cabin
Old 13th March 2015, 05:36 PM
nath nath is offline
Default d4 rear seat bench
anybody care to enlighten me how the hell you remove the rear seat bench
i am aware of the 3 clips at the front edge of the seat
and removed those easilly
i am now trying to release the rear part of the seat which has either been glued or welded in it would seem
there is some type of clip holding the outside of the seats
but it doesnt appear to want to move either up or down
the only other thing i can see is a bolt which holds the bracket to the body
but this is obscured by part of the seat frame
need to remove rear seat to enable me to thread wiring for rear camera
thanks nath
Old 13th March 2015, 06:11 PM
Don't know the D4 specifically, but the standard method on almost all cars is to remove the fixings below the front edge (often a bit hidden in carpet) and slide forwards.
Not sure if ISOFIX mounts can cause a problem, do you have those?
Old 13th March 2015, 11:57 PM
ive removed the 3 anchor points at the front of the seat but am unable to lift the seat high enough to look underneath to see whats holding it in place
no idea if it has isofix or not ... but i do have an angle grinder
Old 14th March 2015, 09:39 PM
Yep, the angle grinder will do it, but you maybe better off just forgetting the 20p you lost down there
Old 15th March 2015, 09:46 AM
finally got them out
stupid idea seats are clipped in at back
Old 15th March 2015, 10:22 AM
What sort of clips, where exactly and how did you reach and release them?
