New fault code?!?!?.....
Eml came on so plugged in my code scanner......... 17978???
That code isn't in the wee handbook that came with scanner?!?!? Anyone help please, thanks |
17978/P1570/005488 - Engine Start Blocked by Immobilizer
Possible Symptoms Engine starting but stalling immediately Possible Causes Key(s) not matched Instrument Cluster not matched Engine Control Unit (ECU) not matched Engine Control Unit (ECU) Power Supply faulty Possible Solutions Check for Fault Codes in Immobilizer itself (part of Instrument Cluster in many cars, but separate Immobilizer Control Module in some) Check Immobilizer Measuring Values (usually in Instrument Cluster OR Immobilizer Control Module) Match Key(s)/Instrument Cluster/Engine Control Unit (ECU) Check Engine Control Unit (ECU) Power Supply (Relay) Special Notes In case of Engine Starting Issues please make sure that you are really experience an Immobilizer related Problem! Even if the Immobilizer engages, the Engine will still start fine but cut out after 2-3 Seconds. If you are NOT experiencing this behavior (e.g. Engine doesn't start at all) your Problem is very likely NOT Immobilizer related. May be stored in Combination with 01176 - Key: Signal too Low in Immobilizer Control Module. If no other immobilizer related fault codes are stored and the immobilizer related meas. blocks are fine except Engine Start not allowed, in rare occasions it helps to try cold-booting the car. Remove both battery cables from the battery. Short the battery cables together (away from the battery) for about 15 seconds. Reconnect the battery. (Example) Low battery voltage (including a faulty battery) may cause Immobilizer system malfunctions and testing should be done only with a known good battery installed.
______________________________________________ A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
That's great thanks! The car has started no problem after sitting on the drive for weeks unused! Ill clear the code and use the car and see if it comes back! Thanks again
Hey guys, just went out to A8 and when I turned the key the yellow warning light with a key and outline of car started to flash and car didn't fire up first time, it did fire up second time! Is this the start of something bad? What do you suggest? TIA
Could be the immobiliser wire starting to go... Fairly common issue.
Thanks |
It's in the steering wheel shroud, a black wire from memory.. It's the movement of the column back and forward that weakens it.
Mine has been like it for years now, sometimes it's bad and others it's fine for ages.
Immobiliser wire
I had this problem....it isn't too difficult to do....have a look at repair sticky on immobiliser wire.
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
Thanks guys
