Old 6th March 2010, 11:02 AM
darrenjoe90's Avatar
Default laptop requirements
just waiting for my lead to come in the post. wanted to know if vag-com will work on any laptop. i already have a laptop but it is quite large and i use it for many other things. thought it would be best if i bought a new one just for use in the car. will this one be ok or do i need something a bit better ? http://www.ebuyer.com/product/172718
Audi S8 Phantom Black
Old 6th March 2010, 11:05 AM
IMO it wants to be the oldest, least cared for laptop, but with a good battery (or a replacement one)
That way, it can get battered about, sit in the engine bay, fall off the passenger seat, and you're not going to be too fussed by it all... A good battery helps if you need to monitor things on test drives, rather than only when parked up, but arguably a power invertor can get round this...
Spec wise, it doesnt need to be anything fancy - in fact - you're probably better off with a simple, XP based machine than a new flashy vista/windows 7 model....
Old 6th March 2010, 11:07 AM
I didnt really answer your direct question - ! - Yes, that laptop would do fine, but for £200 I'd rather get a second hand job for £50 off fleabay and put £150 towards toys for my motor
Old 6th March 2010, 01:00 PM
thanks for your advise ian. i have just been on fleabay and bought one of those panasonic tough books. its a normal laptop that you can drop or even drive over without damage. only paid 70 quid for it.will probably need a new battery but i should be able to get one cheap. already have an inverter in the boot so i should be covered.
Old 6th March 2010, 01:13 PM
I agree with Ian although I have a s****y £250 Samsung notebook with Windows 7 and 10 hour battery life which I purely use just for Vag Com! Will be handy for Germany.
Old 6th March 2010, 03:51 PM
thebluewhale's Avatar
I've just had a quick look myself. Have you picked up the one with the 6.5 Gig drive in it?
I don't know whether to pick one up or get the old laptop up and running again. It'd probably cost about the same.
I like durability of the Tough books though.
Decisions
Steve
Old 6th March 2010, 06:19 PM
yes steve its only got a 6 gig hard drive but it should be ok for car stuff.
Old 6th March 2010, 06:21 PM
Forum always thinks I'm saying rude things when I'm not! S W A N K Y
Old 6th March 2010, 06:49 PM
Cheers Darren,
Are you going to run Linux or try and make XP run? I think XP may struggle with the amount of ram available.
Geek time!
Old 6th March 2010, 07:36 PM
i am going to run xp on it. i have paid 13quid extra for the memory upgrade. i know its still not much compared to new laptops but it should work ok with vag-com. i am also going to try and put on elsawin. it wont work on my own laptop as i have windows 7 ultimate so hopefully it will work on the panasonic
