Old 7th February 2019, 09:41 PM
Not wanting to muddy the waters with even more possibilities, but decided to do what Mark did and look through my old log files and came across the same 01119 error code in both scans of April 2017 and 2018 (before the MOT).
However, I've never had the big red exclamation mark appear (except when doing a scan with VCDS, but with the same flashes/beep sequence), but have had both yellow warning lights come on and stay on. That's usually accompanied by error code 18265 appearing both in the ABS and Transmission modules, and can only be cleared with VCDS.
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs - Fan Jet Windscreen Washers
Old 7th February 2019, 10:03 PM
i wouldnt have thought that that would trigger a 01119 Gear recognition code.
It won't but, as I said, sounds like 2 problems. Fix 1, work forwards.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!)
Old 8th February 2019, 03:37 PM
Yes, low brake fluid will do the same. Will go and check that now
OK, Brake fluid is towards minimum but not low enough (I would have thought) to trigger the warning and, besides, but i wouldnt have thought that that would trigger a 01119 Gear recognition code. And, yes I have been reading the handbook
Low fluid would have been my guess too....
It might be above minimum, but if you set off in a rapid enough fashion, the fluid could slosh back and register low. I've definitely had this on a D2 S8 before.
I'd definitely top it up, as there's no harm in doing that, and it could help further diagnose that issue....
I concur that the low brake fluid warning is completely independent of the gear recognition code.....
The Family Wagon - 2016 Q7 4M Sline. Adaptive Cruise, Lane Assist, Traffic Jam Assist, Traffic Sign Recognition, Keyless Entry, Pan Roof, Rear Seat Entertainment, DVD Changer, Heated Windscreen, Heated Steering Wheel, 4 Wheel Steering, Air Suspension, Electric Folding Towbar + Trailer Assist, Park Assist, 360 Degree Cameras, Audi Phone Box, Heated Rear seats, Rear Side Airbags, Memory Front Seats, Matrix Headlights, Colour Interior Light Pack, Auto Dim/Dip/Fold Door Mirrors, Rear Blinds, Privacy Glass, 85 Litre Fuel Tank, Heads up display, Electric Steering Column, 21" Turbine Alloys, Reversible Luggage Compartment Mat, Virtual cockpit, Full Leather, Bose, 4 Zone Climate,
2001 D2 4.2 QS Silver, 1997 D2 S8 Silver,
1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey,
2003 C5 RS6 Blue, 1998 D2 S8 Black,
2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue,
2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black,
1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue,
2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black,
2009 B8 S4 Black, 1998 D2 S8 Agate Grey,
2006 D3 4.2 Tdi Blue, 2006 D3 S8,
2007 Q7 3.0 Tdi, 2006 C6 S6,
2011 A7 Sline, 2001 A2 1.4 Tdi Black,
2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue,
2007 4.2 Tdi Q7, 2006 S4 Cab Silver,
2010 RS6 Saloon Black , 2007 TT Roadster,
2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro,
2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black,
2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi,
2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi)
2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey,
2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black
2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue
2016 S5 Coupe Launch model
Old 8th February 2019, 09:34 PM
Thanks for all the suggestions and advice. So, first thing is to top up the brake fluid and, secondly, do a re-scan after taking it for a spirited drive.
2002 D2 S8 Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18 Avus, ski hatch, Bose, auto dim rear view mirror, rear blind.
Old 10th February 2019, 01:48 PM
Well, the brake fluid level does seem to be the cause. Took it out today to pick up some brake fluid and going around a roundabout without acceleration it alarmed. Topped up the system and then took it out again - no alarms despite some hard acceleration/maneuvering
As the photo shows the level is not that low but I believe the sensor is at the front on the low level line so acceleration will cause an alarm.
Check scanned and cleared the DTCs so will take it out again after the rugby today and check what happens to the 01119 Gear Recognition signal....
Thanks for the suggestions guys.
Old 10th February 2019, 03:17 PM
Huzzah! Hopefully the 01119 code is just from using Tiptronic like some cars seem to do.
Worth checking the state of your brake pads with the fluid that low - it has to have gone somewhere
facebook.com/D2Doctor
Old 10th February 2019, 06:51 PM
Yes indeed, that was the next thing worrying me! Both front rear calipers have been refurbed in the last couple of years and the pads replaced within the last two years and my mileage is pretty low these days.
Old 11th February 2019, 02:17 AM
27litres's Avatar
27litres 27litres is offline
look through my old log files and came across the same 01119 error code... have had both yellow warning lights come on and stay on. That's usually accompanied by error code 18265 appearing both in the ABS and Transmission modules, and can only be cleared with VCDS.
Is this still occurring?
I would suspect MAF in this case.
Any rough shifting, particularly at WOT?
Marty
____________________
2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, XCarLink, Bose, clunky old phone in arm rest!
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 11th February 2019, 09:59 AM
Car has been off the road and under wraps since May 2018, as the plan was to fix it up and keep it long term. Current daily is an '04 A8.
Had to Google WOT first, but don't drive the car like that. More of a 'Driving Miss Daisy' driver. I do have the odd hiccup with the gearbox, and the F125 switch is on my list of purchases.
Old 23rd February 2019, 09:10 PM
Markiii Markiii is offline
Watching with interest as I get the same issue intermittently. Cured by a restart but oddly always seems to require I remove the key
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
