Old 20th February 2015, 11:54 AM
Default Splicing Video leads
I am in the process of fitting front, rear and cargo cameras to my horsebox. I have a system that comprises 3 cameras, a screen that will show multi views or single view when reversing, associated cables and connects up straight forward enough.
I also have DVR that will record on continuous loop up to 4 inputs and via a remote control will provide picture out via a video lead to a screen. My screen however will not take plain video in but has 3 x 4 pin plugs to attach the cameras to. The same plug is on the DVR (4 pin).
I want to be able to see the rear view and load cameras while in motion and record all three streams to the DVR. There is a switching ability from the reversing light switch that will priorities the rear view camera on the screen while reversing. The DVR is SSD based and the cards can be removed and viewed on a PC
My question is can I just splice in a second set of connectors, one for each camera so the cameras are sending the picture to the screen and the DVR at the same time. each plug has 4 wires +, -, video and sound I'm guessing!
Any video gurus out there?
TiA
CtL
Old 20th February 2015, 12:09 PM
Yes in short, you should be able to splice or use Y adapters to make the video outputs go to 2 places at the same time.
You lose a big of signal strength but its not normally an issue with just a single split.
Video / coax can be sensitive though, so if it is any sort of coax cable with a coax plug, a proper Y cable should do a better job than a hack with a soldering iron.
Budget cameras might have a 4 wire configuration exactly as you mentioned with a shared ground, but that might make them more sensitive to the signal being shared.
Suck it and see will be your friend in this instance me thinks....
I would have replied quicker, but I got stuck for ages on the opening sentence where you said you had a horsebox....
Old 20th February 2015, 12:42 PM
its worse than that - he has a horse too. . . .if he can stay on it!!
Old 21st February 2015, 08:06 AM
Ian,
Thank you for your prompt reply. I was going to announce my new off road capability when it was all up and running.
Neil,
I was going to suprise everyone but now you've spoilt it, you rotter! 😝
Yes, I do indeed have a very capable off road transport medium called Minerva.
Quattro will only take you so far!
Old 21st February 2015, 09:46 AM
Well, at least its Quattro....
Old 22nd February 2015, 02:51 PM
Not named after a certain Pusser's grey war canoe of the same name by any chance?
Old 24th February 2015, 08:18 PM
Possibly. Or a certain Roman goddess......
