Old 22nd April 2019, 11:17 AM
peiiider peiiider is offline
Default BEM component protection ?
So, easy question..
Does the Battery/Energy management ecu have component protection ? Wondering if I should try a newer/used one from ebay to see if it helps on my random power saving «cuts» and mmi 10% warnings.. 2006 3.0tdi.
06 A8 3,0TDIq My daily driver and project...
97 A4 1,8Tq. Powered by a 4,2 from the '01 S6, full rollcage, FIA seats and 6-point harnesses, B5 RS4 KW Competition race suspension, B6 S4 brakes, 18" Toyo RS1 slicks, carbon fiber roof. V8 trackday racer
14 VW Caddy 1,6TDI from my employer..
(X)00 A8 2,8q, (X)97 A4 1,8Tq, (X)92 S4 2,2Tq, (X)92 80 2,3E
Old 22nd April 2019, 03:30 PM
Somerandomguy's Avatar
No it doesn’t- If you have the VW software /hardware there’s even a switch over procedure to transfer settings to the replacement module.
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 22nd April 2019, 09:17 PM
Thumbs up
I have full version vcds/ross tech cable if that’s what you mean
Thanks !
Old 23rd April 2019, 07:17 AM
I meant VAS-PC, i just couldn’t remember the name of it. it’s not essential to do this as VCDS will let you add in the battery serial number coding manually anyway
Old 24th April 2019, 03:28 PM
Check the SW version. I saw a 2009 one on ebay and what I think is the software version on the label (055 IIRC) was the same as my 2006. While there are later versions available than what is on these, I think it was installed by workshops.
Having said that I just remembered my BEM was replaced under warranty during the original owner's reign so could be 2007 or 2008 BEM.
Old 24th April 2019, 03:32 PM
I’m almost sure my 06 has the most recent software, I just suspect it’s not working properly for some reason..
