Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 3rd February 2017, 06:06 AM
A8 Ian A8 Ian is offline
Default Audi lane assist to Active lane assist
Hi all,
My D4 has lane assist, acc stop and go, side assist, night vision ect...
Does anyone know what parts would be needed to convert this to active lane assist as per the 2015+ models ?
Many thanks
Ian
Old 3rd February 2017, 07:22 AM
I suspect you would be looking at a new power steering system as the later cars were significantly different in that area, a by-effect being active lane assist.
They no longer had a shaker in the steering wheel, instead using feedback through the column - meaning you didn't have to opt for the ugly 4 spoke to get lane assist.
To be honest - In my opinion any form of lane assist is something I'd switch off on a D4, just leaves you feeling detached (and sometimes confused, when you thought it was turned off but you caught the stalk) but isn't good enough to be really useful
Old 3rd February 2017, 08:29 AM
So will the newer model have electric power steering and mine has hydraulic? ...not that I lift the bonnet much but I should know the answer to that.
Is it even remotely possible on a pre face-lift? (I'd really like to have it
Old 3rd February 2017, 08:46 AM
Exactly that I believe - so not much chance it will be viable I'm afraid
Old 3rd February 2017, 08:52 AM
Just opened up a VCDS scan from a face lift car - they have an additional module for the electronic power steering
Address 44: Steering Assist (J500)
Part No SW: 4G0 909 144 T
My pre-facelift doesn't have that module.
The other (slightly more useful, maybe) feature with the face lift is the "Parking Assist" which can park your car for you - all be it in a dim-witted way that will leave you embarrassed to get out afterwards (lot's more shunting backwards and forwards than it takes if you can just reverse yourself).
Old 3rd February 2017, 09:01 AM
Thanks Paul for your help.
I can't find any evidence online to suggest that the power steering system is different. . Just browsing power steering pumps online for 2010+ A8s they all seem to look the same even up to 2015 units.. seems to be no pully on the unit rather a motor ...
I'm most certainly no expert mind so I could well be looking at the wrong thing!
If they all have electric hydraulic power steering is it possible the only difference is the address 44 unit? ... maybe some kind of motor that turns the wheel on the steering column?
Old 5th July 2021, 07:14 PM
v8quattro42 v8quattro42 is offline
Originally Posted by A8 Ian View Post
Hi all,
Many thanks
Ian
Hi Dude
Can I ask you for full vcds scan of your Audi please as I’m on my way to install Lane assist please.
Regards
