Old 14th February 2019, 10:33 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Default EPB MIL. Again...
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00568 210 01865
VCID: 2045FE59F3D8C29
2 Faults Found:
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 254352 km
Time Indication: 0
Date: 2019.02.14
Time: 09:08:01
Freeze Frame:
Voltage: 6.63 V
Count: 40
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Time Indication: 0
Freeze Frame:
Voltage: 9.73 V
Count: 61
It wouldn’t release this am from the button, but auto released from the throttle.
A while back I had the EPB ECU replaced, after replacing pads and discs. Maybe last summer I replaced the electromechanical part of the near side Galilee after that age itself.
Does anyone have a guess as to what’s going on?
I’ve bought an EPB ECU from our sponsors. The brake pads aren’t old enough to be worn, surely...
2007 Mini Cooper S R56
Old 15th February 2019, 08:37 AM
This could very well be a now faulty EPB (Handbrake) Switch which forms part of the circuit and would give that fault if it was intermittantly failing, and hopefully if A8 Parts have a second hand one then you could swap it easily and see if it cures it for you.
Audi are notorious for EPB switches failing, our 4 Year old FL D4 just had one fail and it decided to not let me turn off the parking brake which was a problem when I was half way through customer meetings! Fortunately I had VagCom with me and used it to go into the brake module and tell the calipers to retract the brakes, and I then just left the handbrake off until I was home. a new switch from Audi at £50 fixed it and now all is good again
Old 15th February 2019, 09:33 AM
Johnmed's Avatar
Ooh. The switch did pull up a little too easily the other day. Maybe it is that. I’m in morocco at the minute. Will try and email our sponsors.
Thanks buddy.
Old 15th February 2019, 01:16 PM
Johnmed's Avatar
Now got a switch winging its way to my house from our fab sponsors.
Will give me something to try when I get back in the country.
Old 22nd February 2019, 02:19 PM
Johnmed's Avatar
Just picked up my EPB ECU and switch from A8parts at the Post Office and..... The thing has only fixed itself (for now). No warning lights. Works fine. Cycled it a few times. What the f....
The battery was low, having not been used much before we went away and upon return even lower. I know this can cause gremlins, but it’s a bit odd.
Old 23rd February 2019, 07:16 AM
I swear these cars do it deliberately some times if they don't get enough attention! 😜
Old 23rd February 2019, 07:18 AM
Johnmed's Avatar
Possibly. It’s quite the love/hate relationship!
