Old 6th February 2017, 05:55 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Diesel purging...
Howdie Chaps and Chapettes.
I thought purging was a thing of the past, the thing your Grandad would do to his old W123 200D. But I've been reading more about it recently, and it got me thinking. This is only my second DERV, so I'm not massively experienced with them.
Has anyone done it to their TDi, is it appropriate for the things, could it damage any internal seals?
All the best. John
2007 Mini Cooper S R56
Old 12th February 2017, 12:57 PM
What do you mean by purging?
Old 14th February 2017, 02:33 PM
Johnmed's Avatar
Like this mate:
https://m.youtube.com/watch?v=iq_ZGh1KEec
Old 14th February 2017, 06:18 PM
I would say no way hose. You would be breaking the fuel system and putting in unfiltered fuel. The tiniest spec will clog the injector. The injector is a very fine instrument with 4-7 invisible holes in the tip that fire at 400-2000PSI (depending on load). Can you imagine how fine these are? A bit of lint of dust will get stuck in it forever. The inside of the fuel system is clean anyway.
Old 14th February 2017, 08:27 PM
Johnmed's Avatar
Thanks for that. Always nice to hear a more informed point of view than my own.
Old 15th February 2017, 07:07 AM
They did use additional filter in the video but I don't think this method will work on PD and CR engines with electrical lift pump in fuel tank, only with mechanical lift pumps which are part of main VP37 and VP44 pumps.
Old 15th February 2017, 12:40 PM
Johnmed's Avatar
Won't be something I'll be doing any time soon. I don't really understand why purging would be needed, if filters are changed regularly.
Old 15th February 2017, 01:52 PM
47p2's Avatar
47p2 47p2 is offline
How about filling a new filter (next time it's due a change) with the Liqui Moly Diesel Purge
Nite Blue 3.0L SE Quattro
Old 15th February 2017, 02:16 PM
Johnmed's Avatar
I thought of using the filter itself too, but then would the new filter be full of shmutz from the purge? Maybe use an old filter?
