Old 2nd May 2019, 01:21 PM
Default F125 Switch Replacement - Need Confirmation of Which One I Need
With the car recently going through the MOT cleanly and with no advisories, I've finally decided to tackle the intermittent F125 switch and the rear output shaft seal together (as I'm starting to get that 'aroma' again - was replaced four years ago). I already have a seal, but need to order up the switch, and want to double/triple check I order the right one.
Using ETKA for guidance, there are two possible switches that I could have for my AKC engine, an 8-pin and a 10-pin, depending on VIN number. Now, looking at the F125 switch replacement guide here:
http://www.audipages.com/Tech_Articl...chreplace.html
it shows the end of the 8-pin switch:
and this is an image I found of the 10-pin switch:
If we look at this image from the F125 guide:
we see two cables running to the left side and then below the green id plate. If I am correct, then the one with the red box around it is going into the valve body, and the one marked with an arrow is the F125 switch (although the connector is only just visible).
Now, I didn't follow this second cable to its destination (as the car was on the ground with the wheel turned out), but I did disconnect it at the arrow and it matches the image of the 10-pin one above (a flattened D-shape with 10 connectors, although only 9 occupied). That sort of confirms that I need the 10-pin version, but by way of triple checking it, can someone (ahem, MJ) confirm from the VIN and ETKA, that the 10-pin is correct.
This is what ETKA shows for the F125 switch:
and my VIN number is WAUZZZ4D92N002072.
The VIN descriptions in ETKA have always confused me, but since my car appears to have the 10-pin connector, does the descriptions shown sort of translate to 'if your VIN is greater than 4D-1-000 001 then you need the 10-pin, but if it's less than 4B-Y-020 000 then you need the 8-pin'.
ID:	21506   Click image for larger version
ID:	21507   Click image for larger version
ID:	21508   Click image for larger version
Old 2nd May 2019, 01:55 PM
Pretty sure yours will be the 10-pin one Sean, as mine was, but MJ is the translation expert....
Old 2nd May 2019, 01:58 PM
+1.
Old 2nd May 2019, 05:24 PM
Exactly ^
The 9 and the N in your VIN are the two '-' in Etka's numbers so yours translates to 4D-2-002072 (effectively a 2002 model year) ergo the 10-pin switch
The change to the 10-pin switch is basically the start of the 2001 model year, but since UK registrations don't correlate directly to Audi's model year (which is August when they come back from their summer holidays) it can be a bit confusing.
Old 2nd May 2019, 06:07 PM
Quite apt that it should be August
Old 2nd May 2019, 07:11 PM
Exactly ^
Brilliant. Thanks to all who responded and confirmed. Now to beak open the piggy bank.
Old 11th May 2019, 12:48 PM
oldnick oldnick is offline
lucky you
with a chinese copy being avaialble for £32 from hermes trading on Ebay why not buy a couple ?
tps quoted me £320 for an 8 pin
