Old 19th May 2019, 01:14 PM
Drivers side does look a bit low.
Old 19th May 2019, 01:34 PM
Those pics illustrate the point actually.
The rear door here needs the seal moving forward
and the front door here needs the seal moving up
You'll get a fair bit of wind noise (relative to the rest of the car) from both of those gaps.
ID:	21640   Click image for larger version
Old 21st May 2019, 06:53 PM
Originally Posted by hunker7 View Post
Really don't want to be messing about, probably will be sourcing whole frame. Any idea on what it could cost me?
I bought a whole upper frame including the window lift mechanism (excluding motor and glass) a while back from our sponsors and it was way under £100.
Best give them a call and discuss exactly what you need.
Old 3rd June 2019, 09:11 AM
hunker7 hunker7 is offline
All adjusted, slight improvement but seems like sunroof is the main cause. Seal might have shrunk over the years and now there is a gap, there is no adjustment is there? As in make sure it sits flush?
Old 3rd June 2019, 09:23 AM
I think there is actually, but its a while since I saw one in bits. I will have a look in the manual later.
Old 3rd June 2019, 10:09 AM
Check out the following document in the D2 Tech Dump thread, under D2 - Common Faults. Pages 125-126 are what you're looking for:
Service Manual General Body Assembly Exterior (Rep groups 50 55 57 58 60 63 64 66).pdf
Old 3rd June 2019, 10:13 AM
PDF of the procedure attached
Ha too slow
Old 3rd June 2019, 11:32 AM
Awesome. Thanks guys, fingers crossed.
