Old 6th November 2016, 03:04 PM
I have to tackle this soon too. So I am confused now, does cutting the wires (open circuit) work just as well as shorting the wires (closed circuit)
Sounds a bit strange
Old 6th November 2016, 03:26 PM
No. Open circuit (thigh pad) is a fault.
Old 6th November 2016, 05:47 PM
oldnick oldnick is offline
just cut the blue and white wires in the black sheath going to the thigh pad
then use your multimeter set to ohms and see if current passes in the pair going into the thigh pad , should be no circuit [ reads 1 for no circuit ]suggesting the pad was faulty ....tuck this into the thigh pad , now out of use
next join the other ends of the the blue and white wires to make the circuit ; dashboard warning light should now go out when you turn on the ignition , as should the warning sign in the bottom of the rear view mirror
just for safety ~i disconnected the battery first of all , probably not required but who knows
worked fine for me
Old 6th November 2016, 05:50 PM
CBA, no problems.
Otherwise spot on.
Old 7th November 2016, 08:47 AM
worked fine for me
Thanks, it makes sense now
Old 8th November 2016, 02:47 PM
pete-p's Avatar
pete-p pete-p is offline
I've been watching this thread for a while as the airbag light on mine was a bit temperamental, haven't touched it and it seems ok now.
but what about the sign underneath the rear view mirror ....I had forgotten that ....it says passenger seat airbag off when~I turn ignition on then promptly goes off ...is that what it did before? didn't take note !!!!
I can confirm that it does light up briefly on ignition and goes off.
Cars...
Old 8th November 2016, 05:03 PM
thanks pete , obviously what it is meant to do ...mind you my description is bad , it is actually nearer to the overhead interior light
at least if your airbag light stays on you will know the most likely place to start looking !
Old 8th November 2016, 05:08 PM
My Volvo has a warning light in that area for the passenger air bag and it just stays on! Designed to behave that way apparently, but why?
Old 12th November 2016, 02:06 PM
quite simple originally ; the swedes used rear facing child seats in the front passenger seat and that light showed when you had switched the airbag off for that reason ......in case you forgot to switch it back on when you took the child seat out ; or so I was told at the gothenberg factory
Old 12th November 2016, 02:09 PM
Not convinced really, it's the other way round. With NORMAL settings the light is on all the time the car is running to tell you the airbag is operational.
