Hi guys, me again. Just trying to sort a let down D2
![]() I have all door cards sorted with new clips and seals as it should have. Thanks guys ![]() |
The ideal position for the window frame is with the rubber surround just touching the door frame so it makes a seal but isn't jammed up against it. I've noticed its quite common for the top corner of the seal to drop slightly - presumably because the rubber has shrunk over time. This leaves a few mm gap at the top which can cause a bit of wind noise. I've not investigating fixing it yet but I think it'll need the whole window frame removing and the seal repositioning.
There are also rubber seals on the leading edge of the door skins to seal off turbulent air. You can get a bit of noise if one of those is missing. |
I adjusted mine (NSR) recently after replacing the frame, it's only 4 bolts to loosen that hold the whole frame in place.
I just made sure that the seal was joined up and smooth on the outside and it was all good.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions, ski hatch retrofit; extended leather. Aftermarket DVB-T, reversing camera and full XCarlink (Bluetooth etc.). 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. AgateGrey/Platinum. Every option (I think) except electric rear seats, tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon, Auto-dim mirror, Leather, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
As others have said look at the adjustment.
Also I can highly recommend using some Gummi PFlege on the seals to puff them up a little and brings them back to life a touch.
-- 2001 Audi A2 1.4 SE - Jaipur Red Pearl 2002 Audi D2 4.2 S8 - Ming Blue Pearl 2002 Audi D2 2.8 A8 QS - Audi Silver -- Last edited by Nognar; 13th January 2019 at 12:50 PM. |
Thanks guys for info. Part of me thinks it is sunroof and not doors, but it's hard to tell. Does sunroof adjust with little Allen key like most cars?
Never tried it tbh. Does it sit flush with the roof?
