Old 14th June 2020, 07:35 PM
Audifan Audifan is offline
Unhappy broke my fuel pump
I wasn't careful when I was tightening the nut for my new fuel pump and snapped off one of the terminal post looks like I need to buy a new fuel pump
ID:	24395   Click image for larger version
Last edited by Audifan; 9th November 2020 at 09:35 PM. Reason: switched pictures to attachment
Old 14th June 2020, 08:21 PM
Maybe a stupid idea but if you're careful could you not try soldering the terminal to what remains of the stud? Your gonna scrap the pump now I guess so maybe worth a try.
Audi S8 D2 2002 88k mls
Old 14th June 2020, 08:53 PM
or drill and tap it?
Old 14th June 2020, 09:50 PM
There isn't much left of the stud on the fuel pump. Is soldering even a good idea?
It's possible but I have no idea how far I can safely drill down into the broken stud on the fuel pump side. Also finding a small enough replacement stud to screw into the newly drilled hole and have it tapped out to receive new stud.
Old 15th June 2020, 04:54 PM
Given where it is, the difficulty of replacing it, and the consequences of it failing, I would be inclined to just chalk that one down to experience and replace it.
The max torque for an M4 bolt is around 2Nm, or 17 inch-lbs so barely anything really.
Old 15th June 2020, 05:32 PM
This is the nut for the negative post on the fuel pump and it looks like it has a nylon insert?
Here is my attempt at fixing my broken fuel pump stud. I was able to drill and tap the hole.
I was able to get stainless steel screw, washer and nut for the repair. Unfortunately I wasn't able to get the hole drilled completely straight .
Got the head cut off and now I'm wonder if this is going to be a problem as this is not sitting straight and could cause a problem?
That's what I have been wondering if it's worth the trouble fixing it.
Yeah I know it doesn't need to be super tight for that nut. I guess I was super excited that I finally got everything I needed to start putting my new fuel pump back together and was in a hurry and over tighten that nut and it snapped
ID:	24397   Click image for larger version
Name:	repair fp 1.jpg
ID:	24398   Click image for larger version
Name:	repair fp 2.jpg
ID:	24399   Click image for larger version
Name:	repair fp 3.jpg
Last edited by Audifan; 9th November 2020 at 09:49 PM. Reason: switched pictures to attachment
