Old 16th August 2018, 11:31 AM
Default Another MOT pass
You never know what will happen when the rules change, but my trusty D2 sailed through again and has another almost 13 months of approval against it.
Just one advisory, one side the rear bake pads are wearing thin. But it's due a service anyway.
They struggled initially to get it through emissions, though I think the mechanic enjoyed revving the engine to get the cats warmed up.
Simple reason really, it's no distance from home, was absolutely chucking it down and the last few hundred yards were through really deeply flooded roads.
But once properly warmed up the lambda figure was spot on and HC and CO were zero.
Old 16th August 2018, 03:15 PM
Good to hear
My MOT is due now, I am struggling with the headlight issue really hoping I can get them adjusted so it passes.
Old 16th August 2018, 03:52 PM
pete-p's Avatar
pete-p pete-p is offline
Very good
Cars...
Old 16th August 2018, 04:48 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Good news - another year of happy motoring
My 8 also struggled to get through the last MOT emissions test.....then I remembered I don’t have cats
2016 S5 Coupe Black Edition - Ibis White
Old 16th August 2018, 04:56 PM
I'm not convinced that a "good" S8 engine, properly warmed up, actually needs them anyway.
I ran for a few years with one rattly cat and when tested it was always spot on.
Eventually I had it replaced and it turned out that there was literally nothing inside it, apart from one loose lump of ceramic substrate. The rest had disintegrated and departed via the exhaust long ago!
And after that expensive exercise it was exactly the same, but quieter.....
Old 16th August 2018, 06:53 PM
I intend to test mine without cats over the winter to see what it does
Old 16th August 2018, 07:23 PM
RICKY D's Avatar
Mine must be a bad one then
I won’t repeat exactly what my mate said, but it was something along the lines of your emission readings are “ducked”
