Old 13th November 2016, 07:40 PM
voicey voicey is offline
Default Lower door trims
Does anyone know how to remove the external lower door trims? My wife managed to catch a low wall and they could do with a repaint.
Cheers...
Name:	d3 door trim.jpg
Old 13th November 2016, 09:14 PM
1781cc 1781cc is offline
If they are anything like the S4 you should remove the rear plastic trims off each door and then they should just slide out easily - in London, car is in Northampton so can't check but the S4 was easy and my 1997 Audi cabriolet had the same style so seems to be an "audi thing"
Old 21st November 2016, 06:31 PM
Attachment 15150
Old 21st November 2016, 06:59 PM
Thank you very much. Do you know if the screws are accessed from inside the cabin? It's not that clear from the pdf.
Old 21st November 2016, 08:42 PM
47p2's Avatar
47p2 47p2 is offline
I could be wrong but I've a feeling bolts 2 & 4 are only accessible by removing the door cars and the window mechanism
Nite Blue 3.0L SE Quattro
Old 6th February 2018, 11:57 PM
H-M3 H-M3 is offline
Old thread but my pass rear trim could do with replacement as previous owner had it repaired poorly by the looks. Is this removal by removing door card?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 7th February 2018, 08:06 AM
No door card removal. It's two screws at the base on the inside of the door, then slide to one side to free it from the door.
Matt
Old 7th February 2018, 09:07 AM
Cheers fella!
