Old 12th July 2017, 11:06 AM
Default Strange noise
Guys, what could that be??
It takes around 10-15min for the sound to appear when engine/bay gets up to temp. It is on the driver side and I think more bottom part.
Really hard to tell coz the sound is really high pitch which is what you can't hear in the video as much.
Thank you in advance
file attached.
Old 12th July 2017, 04:34 PM
All I can see there is alternator.
It can't be fan as the noise goes away when I rev it ?!?!
Old 12th July 2017, 05:09 PM
Sounds like it could be belt squealing or altenator bearing.
Old 12th July 2017, 07:54 PM
I haven't listened to your video, but have you checked the PAS fluid level. The reservoir is buried and consequently often gets missed in servicing.
Old 12th July 2017, 07:55 PM
If it was Dezzy's car then I would suggest that you remove the pig from the car and instead use a trailer to take it to the abattoir.
Old 13th July 2017, 06:46 AM
trailer? if it has clean trotters whats the problem
Old 13th July 2017, 10:41 AM
Does the D3 have a viscous fan? The coincidence with achieving running temperature and the action of the clutch mechanism on such fans might be something to investigate.
For Dezzy: A friend of mine tried to take his pig to the abattoir in the back of a Clio. Lets say that the journey didnt end well for anyof them - including the car.
Old 13th July 2017, 01:36 PM
I'm sticking with belt at the moment, just needs a slight tighten up. Easy fix
David. I'm not supprised the pig was protesting, a Clio! I would have rather have ridden the pig, athough getting home might be an issue.
Old 13th July 2017, 01:59 PM
I had a similar sound that disappeared when revved. This was on an A4 and it was the water pump. Have you a mechanic's stethoscope?
Matt
Old 13th July 2017, 02:22 PM
Long shaft screwdiver will do if not
