Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 30th December 2019, 07:43 PM
Slabber Slabber is offline
Default Info: Vodafone PAYG SIM APN Settings
Wanting to cheaply test out the SIM slot in my car I picked up a Vodafone PAYG pack at Tesco (no charge for this). I added a fiver's worth of credit, popped the SIM in the slot and...nothing. Kept getting 'The data connection could not be opened. Please try again later.'
After much research and messing about the default APN (ie connection) settings were wrong. Correct ones to use (for PAYG!) in Tel> Data connection > Connection settings are:
APN: pp.vodafone.co.uk
Username: wap
Password: wap
Authentication: Normal
Finally, Audi connect works. Is it worth it? Hmmm....
Old 30th December 2019, 11:34 PM
H-M3 H-M3 is offline
Well at least your mmi reads the sim. My damn one does not recognise any sim.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 31st December 2019, 07:00 AM
Yes - so I saw from a previous thread. Do you get any message when you insert a SIM? I started off with a Three SIM which as I now know won't work on early cars and got a message advising to check the SIM.
Old 31st December 2019, 11:22 AM
I tried Neeldub EE sim also no joy. Only thing I can do now is update the SW as it’s factory version. Again will have to wait on Neel as I don’t have SW update. I see you recently updated yours? Was it easy and did you purchase it from the Stealers?
My data connection is grayed out. So basically it does not at all pick up any sim! I will try to clean the connectors with IPA on some perfume testing paper me thinks.
Old 31st December 2019, 01:42 PM
Really unlikely to be a physical issue with the SIM card slot. If you have an android handset that supports rSAP you can test the theory by accessing the SIM via bluetooth and see if the connection works?
Old 31st December 2019, 02:53 PM
Unfortunately I don’t have android but will see if I can log my friends one
