Old 22nd January 2013, 07:58 AM
Default Lights and Lamps List
Whilst trying to sort out exactly what types of lamps (bulbs) were fitted to the car, I thought that it would behelpful to make a list for my own use so, for example, when a special offer on LED festoons /h7s or whatever came up I would know which type and how many I would need. So I went through the car (2002 FL S8) and listed all that I could find - with the exception of the tiny little things which illuminate the door handles!!
If anyone wants to add to this please do and I have left a few columns for PF cars.
Old 22nd January 2013, 08:43 AM
Puddle lights?
Old 22nd January 2013, 10:01 AM
Puddle lights?
Ah yes, just been out and found those - 5W x 38mm Festoon
I'll amend the table....
Old 22nd January 2013, 10:11 AM
And add Iyole's list?
Old 22nd January 2013, 10:35 AM
I'll try and do that too but am not sure what the 4-figure numbers are (i.e. 6411 etc). If that is a particular manufacturer's number, as opposed to a standard desgination like "D2R" or "H7", then it might be misleading listing it. Wot say Iyole?
I have just looked at some festoons on www.autobulbsdirect.co.uk and under their list of 42mm festoons they list a Canbus compatible lamp of 41mm! Other are just 42mm. I appeciate that the festoon bulb holder can accommodate a small difference in length.
I presume that the interior lamps do not have to be canbus compatible but the number plate lights do??
Old 22nd January 2013, 11:17 AM
Now you are finding out why, despite having replaced my interiors with LED, I have never been keen/couldnt be ar**d making a list or recommendation on here
Old 22nd January 2013, 08:45 AM
Now, IIRC, someone did a similar exercise for LED replacements, so it would be good to combine these and to include variations (I know some sidelight bulbs are the push fit type, for example.
And then, perhaps, it would warrant being a 'sticky'?
Nice work David (but you really should get out more! )
Old 22nd January 2013, 09:59 AM
Iyole Iyole is offline
Here is the list I compiled when I did the upgrade ....
Herewith List of Bulbs required for LED Mod to all Interior, Trunk and License plate Bulbs
2 x 6411 41mm Festoon Type Bulbs - FRONT DOME
2 x 6418 36mm Festoon Type Bulbs - REAR DOME
2 x BA9S Bayonet Type Bulbs - FRONT READING
2 x BA9S Bayonet Type Bulbs - REAR READING
4 x 6418 36mm Festoon Type Bulbs - PUDDLE (DOORS)
3 x 6418 36mm Festoon Type Bulbs - BOOT
4 x 6418 36mm Festoon Type Bulbs - FOOTWELL
2 x 6418 36mm Festoon Type Bulbs - VISOR MIRROR LIGHTS
2 x 6418 36mm Festoon Error Correcting Type - NUMBER PLATE.
Thread.... http://forum.a8parts.co.uk/showthread.php?t=3374
Thanks for the additional Info Dave
2002 S8 D2 F/L
Old 22nd January 2013, 10:10 AM
Just so we get this right, why have we got a difference in the festoon lengths? I noted the "standard" lengths from suppliers (they are generally 42mm or 38mm) and physically checked the length (only against a ruler tho').
Also what is the "error correcting" bulb for the number plate? (Mine looked like standard festoons.)
Note to self - missed the footwell lights..
Old 22nd January 2013, 11:45 AM
I am assuming the 36mm refers to the original bulb length.
The codes 6418 etc are the original bulb ref numbers.
http://www.tunerdomes.com/index.php?...wCat&catId=351
The "error correcting" bulb for number plate has built in resistor to prevent
bulb out error .....
http://www.tunerdomes.com/index.php?...d&productId=79
Hope this helps....
2002 S8 D2 F/L
