Old 22nd January 2015, 05:37 PM
Yep, unless you're lucky enough to have a previous bill for replacing the seal in your service history to confirm if it's the updated seal or not. You can't fit the updated seal without the newer flange type.
Given yours is a 2002 I'd be checking it before ordering the part - both seal and flange should be available next day via TPS so shouldn't be too much aggro for garage doing the job (or you can buy it from Mike for less!)
Old 22nd January 2015, 06:31 PM
I checked the previous works invoices etc but no sign of the work having been done (I would have thought that The Laird had got it done, but no!). I was thinking of buying it as insurance - I dont have an issue at the mo' - but wondered if there was a way of checking without pulling it apart.
Old 7th October 2015, 08:42 PM
Mikey-S Mikey-S is offline
Still have this here, can take to ADI@Castle Combe on the 17th.
Old 27th December 2015, 07:53 PM
Bump. Still have this here. I doubt you'll be able to find one cheaper anywhere else.
