Old 29th November 2020, 12:21 PM
In my expirence it's usually just the wire braking from all the bending over time on OEM sensors. I just cut out the middle of cable and replace with bendy microphone cable. Couple of times that I have tried aftermarket sensors they only last 1-2 years and usually the sensor itself fails.
Old 29th November 2020, 12:28 PM
Heksi's Avatar
Heksi Heksi is offline
Okay, I think I found an answer – Wabco is the original supplier. Thanks to eBay.de and Google image search! Buying Wabco instead of original part (obviously also Wabco) saves around 66 €. This I can accept.
Found also some good info from AudiWorld and Audipages
https://www.audiworld.com/forums/a8-...ative-2841023/
http://www.audipages.com/Tech_Articl...eshooting.html
S8 quattro 6-gang PF / 200 quattro 20V / 944 Turbo / 500 SEC
Instagram @hptalli
