Old 19th March 2015, 02:42 PM
nath nath is offline
the problem i have is this when i go into reverse the parking sensors and the camera come up briefly
for perhaps 2 seconds then the screen goes back to the normal car mmi screen but the parking sensors still work audibly
the brief second the mmi works as it should the screen is just black and i can make nothing out detail wise
and the guidelines are also not visible
i have two fault codes from a scan showing in the 6c module
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Control Module Part Number: 4H0 907 441 HW: 4H0 907 441
Component and/or Version: SG Rueckfahrkamera 0030
Software Coding: 1020003
Work Shop Code: WSC 02313 785 00200
VCID: 65C78D90AC6A8509FD6-8030
2 Faults Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
02283 - Video Connection to Output [End Unit]
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 87980 km
Time Indication: 0
Date: 2015.03.18
Time: 13:57:47
as regards wiring i can see the wires which are connected to can high and low
at both ends so im pretty certain there in the correct place just not sure on what voltage should be going down the wire
im going to remove the can connector again tommorow to check its the correct way round
Old 19th March 2015, 08:57 PM
Somerandomguy's Avatar
Oops, sorry forgot to attach the wiring diagrams
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 22nd March 2015, 05:42 PM
o.k
finally managed to sort this out
there was nothing wrong with the coding and nothing wrong with the equipment
it turns out one of the barbs which held one of the connectors which goes into the back of the 3g mmi unit had broken so the wire was loose
thanks to everyone who replied
nath
Old 11th May 2015, 07:12 PM
damtom85 damtom85 is offline
I will be doing retrofit of reversing camera,
Few quick question : did you have to remove 'component protection' from camera module. Which side of car wires go to front, left or right if you look from back. .
Old 13th May 2015, 05:07 AM
No component protection on the camera module, and I ran the wires down the left of the boot lid (looking for the rear). Both of the cable routes were pretty full already so had a hell of a job getting the wires through the flexible tube.
EDIT:Sorry , just realised this was for your D4, so probabky not much help as mine is a D3
Old 8th June 2015, 09:28 AM
I just receive kufatec lead to connect everything, manual says to drag wire on left side of the car but it shows picture of steering wheel on left, so it is European version. So im a bit confused now on which side I should put wires from back to front
