S8 D3 truly random misfire
Hi folks,
A truly useful and informative forum. I have been plagued by a misfire issue that is truly random. One day it’s cylinder 1 and 9 having misfire counts between 9 and 96 with other eight cylinders on 0. Other times these 1 and 9 cylinder will both be at 0 with other cylinders 4 and 6 having misfires with the others all at 0 - very strange indeed! I’ve since completed the following: Replaced coil packs and plugs. Replaced all connector shells on coil packs Cleaned earthing connections on cylinder heads for coils. Replaced MAF connector shells Unplugged MAF’s with engine idling, resulting in erratic idling as it should be. Carbon cleaned with walnut shell blasting. Visual inspected inlet manifold for broken plastic flaps - ok. VCDS scan resulting misfire codes only for engine. It shouldn’t be compression as the misfire cylinders can change. Can anyone advise of any other checks I can run? Should I power off the battery and unplug ECU connectors and check/clean? Is there an earth connection that can be corroded or something that can cause this? Thanks guys,
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. Last edited by Prefferle; 3rd May 2019 at 06:19 PM. |
Is the battery in good health? Have you checked the vacuum lines for a possible leak? I don't know if VCDS can monitor fuel pressure, but what about a possible clogged fuel filter?
Battery good - less than a year old and no VCDS codes. Vacuum lines mostly replaced - i’ll look into these again. Fuel rail pressure checked on VCDS, so have not replaced fuel filter - I’ll replace. one thing when I reset all codes with engine at idle - it sounds like the engine smooths out for a few seconds before pulling misfire codes again. I willl report back with findings. Thanks.
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. |
Looks like you've covered everything that I can think of.
I just re-read your original post and noticed this line: Should I power off the battery and unplug ECU connectors and check/clean? I only recently discovered that the ECUs on the D3 are just lying exposed in the plenum chamber, and now wondering if that area might be the cause, as I'm thinking that since the symptoms are random in nature, maybe water has got into the ECUs, or at least into the connectors. Since you replaced most of the vacuum lines, and they're probably worse to get at than on a 3.7 D2, I'd opt to investigate the ECU connector first, and at least rule them out before checking the vacuum lines.
Thanks Steamship,
I’ll get straight on that. I’m also hoping to find and clean all earth connections I can find. Regards,
A bit strange and I do not have any experience with D3 S8.
Considering this Quote:
