Old 1st May 2013, 12:55 PM
Conquistador's Avatar
Default Fitting a straight pipe (3.7 V8)
Hi all,
I'm looking into increasing the sound from my A8, so would removing the centre silencers and fitting a straight through pipe achieve this? The V8 burble I've got at the moment is just a bit too sedate!
Removing the rear silencers would make it too loud I think.
And am I also correct in assuming it will still pass an MOT as long as the cats aren't removed?
Thanks
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 1st May 2013, 04:54 PM
Architex matey has removed the back box and his 3.7 sounds the mutts. When I removed the center box on my S8 I got resonance at town speeds. Motorway speed were fine but the was a bit more intrusion in the cabin.
Old 1st May 2013, 06:00 PM
Get along to the annual meet next month and hear it in person!!
the sound with straight pipe and no back box is sublime!
I'll try and take some more video when i get the chance - there is some resonance on mine at around 2500 rpm but otherwise its ok. In a perfect world you would fit a system with valves that can be actuated so you get the best of both worlds but mine was a relatively cheap mod for the awesome sound it makes
Old 1st May 2013, 09:45 PM
Hmm I well come along to the next meet.
Would removing the centre silencers have a bad effect on back pressure?
Or would it be good to just install a bigger intake?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 2nd May 2013, 07:23 PM
You need to come along to the Annual meet, its a great weekend and it would be great to take a look at your car!
Video from when we first fitted it is HERE
I'm hoping to have the 390mm W12/Bentley Front Discs on by then with some Bentley Covers so you can see if you like the size!
Old 17th September 2013, 03:45 PM
Car booked in next week to have all silencers removed apart from the rear most boxes where the exhaust tips are attached
Getting it done by AMD - www.amdtuning.com
They seem quite competent and work on a lot of Audis going by their gallery.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
