Old 8th May 2016, 12:09 PM
roberto's Avatar
roberto roberto is offline
Default Solar Charger Aldi £13
looks same as mine bbargininit
Old 8th May 2016, 01:17 PM
homer simpson's Avatar
This one?
https://www.aldi.co.uk/solar-charger...70667036486600
Old 8th May 2016, 01:22 PM
1781cc 1781cc is offline
Thanks for that - just ordered one for the cabriolet
Old 8th May 2016, 04:38 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Ordered. Cheers Robert.
2007 Mini Cooper S R56
Old 8th May 2016, 06:18 PM
No OBD connector?
Old 8th May 2016, 06:27 PM
roberto's Avatar
No OBD connector?
use the fag lighter daddies sauce
Old 8th May 2016, 06:33 PM
As discussed elsewhere, that is vehicle-dependant.
Old 12th May 2016, 04:07 PM
After playing with solar sunroof to charge battery last year I did not have much hope for this charger but at £13.99 it was cheap enough to try it out.
So it arrived today, it says in specifications ratings at max power: power 2.4W, Voltage 17.5V, Current 138mA. I tried it on old, half empty but still usable battery in the garden with the panel pointing directly at sun. Open circuit voltage 23V, battery voltage 12.28V without charger connected, 12.3V with charger connected and slowly climbing, current 151mA, total power 1.85W. Put in the shade and current drops to 13mA.
So it's pretty much as I anticipated, it will not charge up flat battery, might just stop it from discharging during bright daylight sun but will not charge enough to make up for the charge lost during dark hours. Overall it will slow down discharge so your battery might last 1.5 months without driving instead of 1 month. To keep battery fully charged you would need 3 of these panels or 1 that is 3 times the size assuming it will be pointed directly towards sun.
Old 12th May 2016, 04:11 PM
Johnmed's Avatar
Mine came yesterday. The plan being to install it in a car at the in laws place in France. I too thought it was worth a £14 punt...
Old 12th May 2016, 06:27 PM
oldnick oldnick is offline
are the wires that long ?
