Old 8th March 2012, 12:28 PM
Default Sports mode and 6th gear.
I'm convinced, really really, sure that when I had my 2003 plate 4.2 D2 that if you put it into sports mode on the gear selector, and then attempted to change gear with the paddles on the steering wheel, that it only showed gears 1 to 5.
I'm also convinced this was the case with my recent B7 S4.
You put it into sport, and it forgets about 6th gear. Not unreasonable i guess if you're being really sporty.
But - My new D3, a 2006 3.0 Tdi definitely does not lose 6th gear when you put it into sports mode. This is really very good, as in Drive its a bit too sluggish for my preference, but wouldnt want to drive in Sport all the time if it was never going to use 6th.
I'm 99% sure I tested this on Richards new 4.0 and it didnt lose 6th either.
So, Is this an age thing - Or a petrol / Diesel thing ?
Can those D3 owners out there with flappy paddles please test and report back for my sanity please?
Old 8th March 2012, 01:14 PM
AusA8 AusA8 is offline
D3, V8 petrol, MY03/4 - 6th shows in Sport mode.
A8 4.2 S
Old 8th March 2012, 02:59 PM
My 4.2 Petrol doesn't show 6th in 'S' when you use the paddles.. Need to check the 4.2 diesel later.
Old 8th March 2012, 03:04 PM
My A7 shows 7 gears in both D and S mode and 7 in Manual mode when you switch to it or when you over-ride D or S with the flappy paddles
Old 8th March 2012, 09:45 PM
My D3 S8 can still change up to 6th in S mode. It just chooses to ignore it for most of the time
Old 8th March 2012, 09:54 PM
kal_ay's Avatar
kal_ay kal_ay is offline
What he says ^^^^^^^^^
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 8th March 2012, 10:08 PM
So, it could be newer cars then that have 6th available in sport.....
Need a few more responses, but thanks for the inputs so far
Old 9th March 2012, 12:18 PM
Joe2.0E Joe2.0E is offline
My 2004 3.0TDI will change into 6th gear using the flappy paddles when in Sport mode.
Old 24th July 2012, 11:02 PM
Malairt Malairt is offline
My 2008 4.2 diesel sport changes up to 6th if I'm not accelerating and doing about 80.
Old 26th July 2012, 01:36 PM
A8Jas A8Jas is offline
Yeah my 2007 D3 3.0tdi shows 6 in S mode and you can flap up to it. Doesn't shift into 6th automatically much though - maybe I'm not going fast enough!
