Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 27th April 2016, 02:59 PM
Audi did it in an attempt to resolve a bluetooth issue. In the end they installed a brand new 5F unit, latest hardware revision that fixed the problem.
Having searched a little i think one of the downsides of 0900 is that they have "closed" a function that was used for "non-dealer" map updates
Old 27th April 2016, 03:09 PM
can you see the version of the mmi in a vcds scan, on the d3 it was in 07 Control head, but this isnt the case on the D4
Old 27th April 2016, 03:10 PM
explain more - i thought map updates were done by downloading from the audi connect thingy and loading via sd card.
Old 27th April 2016, 03:14 PM
Have a read of this - http://www.a5oc.com/forums/a5-genera...avigation.html
Old 27th April 2016, 03:53 PM
ok thanks for that, been quite a few updates already, trying to work out what mine is on without having to access the car, have a vcds scan but its not obvious which is the mmi fware version if its on here at all
