Help with Suspension Settings etc
Having recently acquired a S8 D2 I need some advice on the following...
1) Suspension Settings... Checked Manual etc and don't come across any Info regarding the suspension settings. On the Web I pick up that this can be done with Vag com.... Is this correct ??? 2) Winsdscreen washer - When I got the Car the reservoir was empty. Filled it ...... but still no water coming out of the jets.... Any advice on where to start and is this a DIY job or do I need to take it in to the "Stealers" to have rectified. Thanks PS... Having an absolute ball with the Car... Really enjoying the Power and Quattro...... Stunning Car and G8 Forum... |
1 - It's a D2 model, so no adjustments available (VCDS only adjusts D3). The only options are a change of suspension to lower the car.
2 - Should be a DIY job. I assume you've checked fuses, etc. You may have a cracked reservoir, or possibly just a gummed up pump, there is a thread on here somewhere I'm sure with the provedure to clean the pump.
I also had no water to washers and it was the pipe to them that had become disconnected near the wiper motor, just a simple push fit back together again
Audi S8 2002, Black (even the chrome bits) Audi RS6 Avant 2008, Daytona Grey Maserati Granturismo 2008, Metallic Nero Carbonio Audi S8 2015, Daytona Grey |
Thanx for the Help Gentleman...
1) The previous owner mentioned the suspension was adjustable and set on Sport Setting... I find this set-up appropraite to my driving style but would like to try-out the other settings... Is this an aftermarket Mod or OEM It could be difficult to locate the Owner who would have had the Aftermarket Suspension hence my Question. How would I be able to confirm if the Suspension is OEM or a Mod....visit an Audi Dealer for Inspection... 2) Tx for the Tips on the Windscreen Washer system... I'll give it a Bash on the Weekend..... |
He probable meant he had fitted an aftermarket adjustable coilover kit which may be adjustable without removal from the car. But it will be a wheels off procedure and may require the front strut being removed to adjust rebound.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
I agree with Conan. Looking at your exhaust video, your car looks lower than standard
Yeah baby!! 2002 Aqua Blue S8 with Milltek - Now sold SL55 AMG Silver with designo red leather and 20" Carlsson 1/16 Utlralight Wheels |
She def is lower than standard and I don't want to change the look.... I am trying to get info from the owner who had them installed so that I can ascertain what make etc it was and the procedure for adjusting..... |
