Old 25th October 2018, 08:56 PM
Default An interesting scan
Hi All,
I was asked to scan an A8 3.0 TDI for a reasonabvly local enthusiast.
Here is the resultant log. I have edited the owner details even though I have his permission to publish this.
Any comments?
Tuesday,23,October,2018,14:40:04:58733
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.2.1.2
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WAUZZZ4E46N0xxxxx License Plate: WV05xxx
Mileage: 242610km-150750mi Repair Order: #01
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 57 61 62 72 76 77
VIN: WAUZZZ4E46N013222 Mileage: 242610km-150750miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 1010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: Malfunction 1010
37-Navigation -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 1010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 1010
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number: AUX3Z0E9375520
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2959D191801C4F0C50-807C
8 Faults Found:
000260 - Mass Air Flow Sensor (G70)
P0104 - 001 - Intermittent - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 212488 km
Time Indication: 0
Date: 2018.02.22
Time: 00:03:26
Freeze Frame:
RPM: 273 /min
Torque: 234.0 Nm
Speed: 0.0 km/h
Duty Cycle: 80.9 %
Voltage: 10.03 V
Absolute Pres.: 999.6 mbar
Mass Air / Rev.: 0.0 mg/str
000258 - Mass Air Flow Sensor (G70)
P0102 - 001 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 212488 km
Time Indication: 0
Date: 2018.02.22
Time: 00:03:29
Freeze Frame:
RPM: 819 /min
Torque: 210.6 Nm
Speed: 0.0 km/h
Duty Cycle: 80.9 %
Voltage: 12.62 V
Absolute Pres.: 1009.8 mbar
Mass Air / Rev.: 487.6 mg/str
004195 - Fuel Pressure Regulation
P1063 - 004 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 212488 km
Time Indication: 0
Date: 2018.02.23
Time: 00:05:20
Freeze Frame:
RPM: 798 /min
Torque: 230.1 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Pressure: 184.6 bar
Duty Cycle: 51.3 %
005705 - Powertrain Data Bus
P1649 - 001 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2018.03.26
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 24.0
Voltage: 11.02 V
(no units): 1.0
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 4.980 V
Voltage: 10.49 V
Absolute Pres.: 979.2 mbar
Temperature: -90.0°C
000275 - Intake Air Temp. Sensor (G42)
P0113 - 001 - Signal too High - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 10.49 V
Temperature: 108.0°C
Temperature: 10.8°C
000566 - Manifold Pressure / Boost Sensor (G31)
P0236 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 4.980 V
Voltage: 5.70 V
001393 - Brake Switch (F)
P0571 - 001 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 14:02:47
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 10.72 V
(no units): 0.0
(no units): 0.0
Bin. Bits: 00000100
Readiness: 0 3 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0090
Revision: --H01--- Serial number: 4002839
Coding: 0000001
VCID: 2541DDA1EC046B6C74-8070
8 Faults Found:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:49
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 4.0°C
T.B. Angle: 0.0°
18271 - Powertrain Data Bus
P1863 - 001 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:35
18290 - Powertrain Data Bus
P1882 - 001 - Missing Message from Electric Parking Brake Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:00
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:00
18275 - Powertrain Data Bus
P1867 - 001 - Missing Message from Steering Wheel (J527) - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:50
16944 - System Voltage
P0560 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
18288 - Powertrain Data Bus
P1880 - 001 - Missing Message from Diagnostic Gateway - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:48
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 40
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:13:04
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 00001 000 00000
VCID: 224BC6BDFD2A9C5411-8076
2 Faults Found:
18265 - Load Signal
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H07 0160
Revision: 01604707 Serial number: AUX3Z0E9375520
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BFA455EBF606843F-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
7 Faults Found:
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
02241 - Engine Control Module; Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:20
00192 - Rear Left Door Handle Touch Sensor (G417)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 76
Mileage: 0 km
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:56
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 12
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:06
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 14
Reset counter: 116
Mileage: 212304 km
Time Indication: 0
Date: 2018.02.16
Time: 00:01:22
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
Shop #: WSC 00000 785 00200
VCID: 2345C3B9E230955C1A-8076
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 13:50:28
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 300BJ057548940
Coding: 0000002
VCID: 2E53228DB9F2283485-807A
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 318BP057515187
Subsystem 3 - Serial number: 7401.02.0500000000218B0158ÿ
Subsystem 4 - Serial number: 8B0158ÿ
6 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:57
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:26:40
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:03
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:29
Freeze Frame:
Bin. Bits: 01
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:57
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 116
Time Indication: 15
Address 08: Auto HVAC Labels: User\4E0-910-043.lbl
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000062140
Coding: 1132625
VCID: 1C37F845DF4EAAA4DB-8048
13 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 209
Reset counter: 76
Mileage: 241771 km
Time Indication: 0
Date: 2017.09.20
Time: 10:16:18
Freeze Frame:
Voltage: 13.50 V
Temperature: 21.0°C
(no units): 192.0
(no units): 34.0
Temperature: 40.0°C
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 18
Mileage: 241771 km
Time Indication: 0
Date: 2017.09.20
Time: 10:16:19
Freeze Frame:
Temperature: 22.0°C
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 115
Mileage: 241775 km
Time Indication: 0
Date: 2017.09.20
Time: 12:11:30
Freeze Frame:
Voltage: 13.40 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 140
Reset counter: 102
Mileage: 241828 km
Time Indication: 0
Date: 2017.09.21
Time: 09:34:28
Freeze Frame:
Voltage: 13.70 V
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242599 km
Time Indication: 0
Date: 2017.10.20
Time: 20:45:31
Freeze Frame:
Temperature: 20.0°C
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:10
Freeze Frame:
Bin. Bits: 00011111
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:31
Freeze Frame:
Bin. Bits: 00011000
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:41
Freeze Frame:
Bin. Bits: 00011000
01853 - Heated Seat; Left Front (Z45)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Temperature: 25.0°C
01854 - Heated Seat; Front Right (Z46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Temperature: 25.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Temperature: 25.0°C
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Freeze Frame:
Voltage: 11.30 V
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:33
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No HW: 4E0 907 279 L
Component: WWS NO RESPONSE
Coding: 0123001
VCID: 55A1AD61FCE43BEC24-8000
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
2 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.28
Time: 23:20:37
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 31
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C583B9A2B0D55C5A-8036
8 Faults Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
01218 - Side Airbag Igniter; Passenger Side (N200)
01217 - Side Airbag Igniter; Driver Side (N199)
00591 - Seat Belt Switch; Driver (E24)
00592 - Seat Belt Switch; Passenger (E25)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65C19DA1AC84AB6CB4-8030
Component: Lenkradmodul H05 0080
5 Faults Found:
01426 - Controls in Steering Wheel (E221)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 66
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:23:55
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 23
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:08:15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:53
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:27
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
Component: KOMBIINSTR. VDO H53 0200
Revision: D05 Serial number: AUDID3E1000779
Coding: 0000413
Shop #: WSC 00011 067 57207
VCID: 275DD7A99608797C46-8072
2 Faults Found:
000 - -
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 51
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:51
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:19
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 1A3BFE5DD57AD494C9-804E
5 Faults Found:
01406 - No Flame
000 - -
02251 - Heater Unit Locked
000 - -
33477 - Terminal Status
Unknown - 004 - - Intermittent
00456 - Control Module for Access and Start Control (J518)
000 - -
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003052170092
Coding: FCFE7FDE2B3504
14 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 116
Mileage: 241790 km
Time Indication: 0
Date: 2017.09.20
Time: 12:41:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 116
Mileage: 241847 km
Time Indication: 0
Date: 2017.09.21
Time: 10:02:04
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:06:33
01207 - Control Module for Auxiliary Heater (J364)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 10:08:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 116
Mileage: 0 km
Time Indication: 0
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 95
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:03
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBG8229001
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 83
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:08:12
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:50
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 92
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:08:12
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
7 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:18
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 221584 km
Time Indication: 0
Date: 2016.04.06
Time: 00:00:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:06
Freeze Frame:
Fault Priority: 1
Fault Frequency: 14
Reset counter: 116
Mileage: 212304 km
Time Indication: 0
Date: 2018.02.16
Time: 00:01:22
Address 28: HVAC, Rear Labels: User\4E0-910-158.lbl
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000017 Serial number: 00000000025011
Coding: 0000000
VCID: 61C989B1B8ACC74C48-8034
3 Faults Found:
01864 - Air Outlet Motor; Rear Right (V219)
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285FD4959B1676044F-807C
5 Faults Found:
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 23
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 168
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:03
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 168
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:39
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 168
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:35
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 3670122
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 13:50:28
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H44 0850
Revision: 00000000 Serial number: 305BE057572015
VCID: 3B751BD97A80CD9C32-806E
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 13:52:15
02445 - Disk Drive Initialization Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:03:36
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000426700008
Coding: 0036004
VCID: 1D31F541C454A3AC2C-8048
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2004.03.25
Time: 00:02:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028590
VCID: 204FCCB5F3268E4407-8074
4 Faults Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 241952 km
Time Indication: 0
Date: 2017.09.23
Time: 10:04:02
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:06
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:10
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503010096
Coding: 0004857
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
10 Faults Found:
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 186
Reset counter: 76
Mileage: 242226 km
Time Indication: 0
Date: 2017.10.03
Time: 09:12:58
01503 - Bulb for 3rd Brake Light (M25)
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 8
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:18
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 34
Reset counter: 116
Mileage: 0 km
Time Indication: 0
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 187
Reset counter: 76
Time Indication: 1
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:35
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:05:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 5
Fault Frequency: 15
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:04
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 80
Reset counter: 76
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:06
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000011655
Coding: 0000013
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:50
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 13:49:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:32
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000056371
Coding: 0010101
VCID: 1E33F24DC952B8B435-804A
5 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 12
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 262140 km
Time Indication: 0
Date: 2018.07.10
Time: 20:19:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 74
Reset counter: 116
Mileage: 242612 km
Time Indication: 0
Date: 2017.10.22
Time: 13:50:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
000 - -
Freeze Frame:
Fault Priority: 3
Reset counter: 76
Mileage: 242612 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM002 0060
Coding: 0028590
5 Faults Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2017.10.22
Time: 14:14:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2017.10.22
Time: 14:15:46
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00468 210 91510
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Voltage: 10.97 V
Count: 247
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Voltage: 8.80 V
Count: 243
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Time Indication: 0
Freeze Frame:
Voltage: 8.28 V
Count: 41
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 5
Reset counter: 76
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:34
Freeze Frame:
Voltage: 12.01 V
Count: 86
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 76
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:56
Freeze Frame:
Voltage: 10.97 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 62CB86BDBDAADC5451-8036
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:26
00070 - Starting Battery Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 8 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:38
00255 - ABS Valves
015 - Cannot Be Tested at this Time - MIL ON
Freeze Frame:
Fault Status: 11101111
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:41
02233 - Left Headlight Power Output Stage (J667)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 242616 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:03
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 396CV057505268
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 175
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:04:53
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 C
Component: TV analog TUNER H14 0270
Revision: 00000022 Serial number: 00000000003528
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 13:53:06
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:19:04
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000006444
Shop #: WSC 00171 210 91005
Subsystem 1 - Part No: 4E0 915 105
Component: von TU3 7023479471
Coding: 344530393135313035202054553337303233343739343731
Shop #: WSC 12345 123 45725
5 Faults Found:
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:38:06
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 01:31:31
02255 - Voltage Measuring Lead from Vbat
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 10
Reset counter: 76
Time Indication: 0
Date: 2004.03.25
Time: 00:00:35
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2017.10.22
Time: 14:18:55
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:26
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028590
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028590
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 116
Mileage: 242608 km
Time Indication: 0
Date: 2004.03.25
Time: 00:06:14
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720505401201
Coding: 0001008
VCID: 2149C9B1F82C874C08-8074
10 Faults Found:
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 32
Mileage: 241933 km
Time Indication: 0
Date: 2017.09.22
Time: 15:42:43
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 20
Mileage: 241774 km
Time Indication: 0
Date: 2017.09.20
Time: 10:26:31
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 29
Mileage: 241774 km
Time Indication: 0
Date: 2017.09.20
Time: 10:26:31
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:02:20
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:05:48
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 18
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 116
Mileage: 0 km
Time Indication: 0
Date: 2004.03.25
Time: 00:00:00
01545 - Sensor for Parking Aid; Rear Left (G203)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 76
Mileage: 241774 km
Time Indication: 0
Date: 2017.09.20
Time: 10:26:30
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 116
Mileage: 242614 km
Time Indication: 0
Date: 2004.03.25
Time: 00:01:28
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H10 0580
Revision: 00000000 Serial number: 00000007541090
Coding: 0010900
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 41
Time Indication: 15
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Time Indication: 15
End-------------------------(Elapsed Time: 03:43)--------------------------
Old 25th October 2018, 09:51 PM
Reading through that list, there seems to be two quite distinct instances of something significant happening to throw so many error codes. There is the one on 2004.03.25 which also managed to get quite a few Component Protection errors, and then there is the second one on 2007.10.22. I suspect battery issues of some sort.
As others would suggest, I'd save the log (assumed you have), and then clear all the codes. There is the option to clear ALL codes, but probably wiser to go into each block and clear them (will take longer, but better). Then have the owner drive around for a few days and then get another scan done, and see what's left.
Old 25th October 2018, 11:03 PM
My thoughts exactly. Save that log, clear ALL the codes by going into each module individually.
Then scan again and save that and scan again after a decent amount of use.
Move forwards from there.
Old 26th October 2018, 01:10 PM
Interesting. Can't say I've even see that many errors before. Like, every single module....
Flat battery aside, which its clearly had, its hard to imagine a routine set of faults that would cause this level of error reporting.
I would wonder if something has been chatting / interfering or confusing the can bus, causing the modules to all fail to talk to each other at some point.
The key thing is most of the failures are 'intermittent' which means it was a fault, and now isn't, so should clear, but weird it happened in the first place...
That might also explain how component protection has kicked in, if the modules couldn't talk to the cluster properly at some point to establish the ID of the car.
I suspect with a good charge in the battery, most of the faults will clear, then you'll be left with the usual suspects to resolve.
If all the errors light up again like this, then its going to be an interesting journey to diagnose....
Old 27th October 2018, 12:50 AM
27litres's Avatar
27litres 27litres is offline
Does the car actually have any issues to prompt the scan Ray?
Otherwise it's a power problem. Make sure the battery and alternator are good, reset and move on...
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 27th October 2018, 06:51 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Hopefully as other posts suggest, a flat battery or power failure has thrown up the majority of these faults.
we've got a Renault trafic in the workshop at the moment - dash it lit up like a Christmas tree. Kept going in to limp mode or simply not starting.
Run our computer over it and had very similar results with almost every CAN module showing power failures/communication errors. Clearing them would not get rid so the fault is current/ongoing.
Started in the engine bay to look for wiring faults or bad connections......the pic says a thousand words.
Wiring has obviously been bodged by a garage at some point and wrapped up in insulating tape. There has been no attempt to even connect the wires properly. Just stripped and twisted together!
Sorry for the post hijack...as you were
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 27th October 2018, 01:49 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Ray, what state is the car in, is this the chappy who is currently unable to use his 8?
If it drives I’d be inclined to do as others have suggested, save, clear, new battery, code battery in and suck it and see.
2007 Mini Cooper S R56
Old 30th October 2018, 10:50 AM
Apologies, I have been rather busy over the weekend and could not access the forum.
Now for the explanation after I have wetted your appetites.
This car has had a few problems, Johnmed was correct in his guess as to ownership.
Started with engine cutting out when the tank was down to approximately half full, resolved by reseating the fuel pump.
This was quickly followed by a wet carpet in the passenger footwell. With the help of our sponsors the owner was able to replace a load of items (I have no idea what or how many) and eventually managed to get the engine running (I think).
He then asked me to do a scan which you have all seen. I think it is every fault possible on every module, but then I am no expert.
At that point I had run out of time so could not start to clear it down. I should be able to visit him tomorrow and will update this thread on what happens.
Old 12th November 2022, 03:58 PM
Garry1's Avatar
Garry1 Garry1 is offline
An old thread I know
But did you get to the bottom of what was the cause
My a8 has similar
Audi A8 d3 4.2 petrol 2004
Blue
Old 12th November 2022, 04:20 PM
My a8 has similar
Probably worth starting your own thread on this, as more people are likely to spot a new thread, as opposed to a reply to a thread (where only those who replied to it are notified).
I'd suggest following the instructions given to Ray, with a couple of other suggestions on top. Provide the original scan if you still have it, as well as an updated scan after clearing and driving it. It also helps if you can provide symptoms of the issues experienced, as well as details of anything you've done to try and resolve the issues. The more information you can provide, the easier it is to eliminate possible causes.
