Old 19th May 2009, 06:34 PM
MiLo
Guest
Posts: n/a
Default Newbie Help RE overheating at Idle...
Hi Everyone
I've not long had the car but noticed today after popping into a shop and leaving the car running other half in the car and the temp was up at around 110 -115 no warning light though oh I did have the air con on and the car doesn't overheat when driving no matter how briskly now i was thinking waterpump or viscous fan fault.
I did check the fan at this point and could get about 3/4 of a turn by flicking it, the thing is I cant remember whether or not it's to spin this much hot or nigh on lock up
the car's done 108K pf D2 4.2 Q Sport with fash
any help greatly recieved
Dan
Old 19th May 2009, 06:39 PM
Have you checked whether the electric fan is coming on? The viscous sounds like it is fine it should be stiff when hot and less resistant when cold.
Old 19th May 2009, 06:50 PM
MiLo
Guest
Posts: n/a
Ah is that front mounted? I take it the little one next to the viscous is for the AC? where do i need to look for the fan switch and fuse Oh and what temp should the fan cut in
TIA
