D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
HELP! GEarknob won’t go back on
Deleted as sorted it!
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust. Last edited by Mossyboy1978; 16th March 2019 at 10:44 AM. Reason: Problem solved! |
Presume you removed the knob by pulling the button out? You have to do the same when you put it back on so the tang on the button engages with the lockout lever. Try pulling the button out, hold it out while you lift the knob off and then push it back down, then release the button and it should engage again.
Did precisely that! Though it was more luck than judgement!!
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust. |
