Old 27th July 2019, 08:20 PM
Durham Durham is offline
Default S8 Ceramic discs judder
Hi, I am relatively new to using the forum although I have had my D3 S8 with ceramics, for almost 2 years now.
Te car has an intermittent brake judder at approx 80mph. the ceramic discs have been removed, checked and replaced to no effect. Judder worse when brakes warm, Non existent when wet and the judder can be avoided by braking really hard. So I wonder if it could be a suspension problem?
Does anybody have any ideas on the? Or suggestions on who would be best to take the car too?
Any thoughts gratefully received.
Thanks
2007 D3 S8 5.2 V10
Daytona Grey, Ceramic brakes, B&O, DTV, DAB, 6 CD, TPMS, Keyless entry, Soft close, Auto boot, AMI, Fingerprint, Black extended leather, Heated sports seats, Alcantara, Carbon trim, Power boot, 7 way electric memory seats.
Old 28th July 2019, 11:27 AM
homer simpson's Avatar
Pads and tyres ok? Btw you have posted in the D4 section
Old 28th July 2019, 11:36 AM
kele kele is offline
If the pad has been inserted incorrectly or the backing clip on the pad is bent or damaged, then you can get these symptoms. And the inner pad may wear more quickly that the outer pad but if the discs have been checked then presumably they checked all that..
I had the same symptoms that you describe on my A6 which turned out to be a damaged pad backing clip.
2022 Mercedes EQC 400
2008 A8 3.0 Tdi sport, B&O
Old 28th July 2019, 04:19 PM
Worn suspension bushes can produce the same symptoms as well, especially on the lower curved arm.
Old 28th July 2019, 06:31 PM
Thanks guys. Will now post in right section! Don't know how that happened
2007 D3 S8 5.2 V10
Old 28th July 2019, 06:47 PM
Thanks. Do worn suspension bushes not show up at an MOT test? If not how best to check them?
2007 D3 S8 5.2 V10
Old 28th July 2019, 09:16 PM
I read that the discs are good for 180k miles as long as they don't get damaged. Depends on use of course. And I think you have to weigh them to establish if they need to be replaced.
Old 28th July 2019, 06:43 PM
Yes. I think good enough. Judder was there when tyres were new. Pads will need replacing quite soon but evenly worn.. Do you recommend any particular pad for replacement? Also, I understand my discs are ok (9ok miles) but is there a way to check how long they have left?
2007 D3 S8 5.2 V10
Tags
brakes, ceramic, d3 s8, suspension
