Old 7th December 2019, 08:55 AM
HPsauce HPsauce is online now
Default Weird start/non-start problem - help needed
I have a suspicion what this might be but don't know enough...…
Started the S8 this morning, no problem, even though it hasn't been used for a couple of weeks. Let it run while I checked the tyres - one has a very slow leak yet to be fixed.
Went out, stopped to post some Xmas cards, got back in the car and it wouldn't start. Lights on as normal but no action whatsoever from the starter.
Bit of a panic as I was on a mainish road and half-blocking the driveway next to the post box!
Somehow by moving the gearlever and operating the key it suddenly started so I went back home.
Turned off, removed key and tried to start - no starter action, not even a click.
Moved the gearstick to different positions and tried again, still didn't start.
Then I kept my foot on the brake AND the key turned to start and began moving the gear lever around and it fired up.
I think it was as I was moving from D to N that the starter kicked in. The engine actually started in a fraction of a second as it usually does.
So I'm guessing this is something to do with safety circuits (and switches?) ensuring you can only start the car in P or N.
But how to I check, confirm and rectify whatever is going on? Thanks in advance for any advice.
Old 7th December 2019, 10:00 AM
Sounds like... F125!
This is the same problem Neil had when the neutral lockout terminal fell off inside the switch - there is a relay in the starter solenoid circuit which is only activated in P or N, otherwise disconnects the solenoid.
It can be bypassed by a bit of chunky wire and some 6.3mm flat terminals if you're unable to get it to a garage to swap the F125 - basically the same configuration as a manual car. There might be a pic in my manual swap thread.
Don't throw the old switch away as I can usually refurbish them if its just a burned or bad contact (like most of them). Not so much if the contact has actually come adrift though like Neil's did.
Whoever designed that stupid switch has a lot to answer for
Old 7th December 2019, 11:14 AM
Oh dear, it's not that long since I had the F125 replaced.
Where do I need to access to bypass it, is it inside the car, engine bay or underneath? and how easy is it?
I'll plug in VCDS sometime to see what that shows, if anything, but I've got other more important things on my plate at the moment (ask Neil!) so the S8 will probably be just parked for a while.
PS I've also still got the old F125 somewhere, I opened it up and took some photos then fitted it together again with some reusable screws/nuts.
Had a quick look but couldn't see anything obvious (to me).
Old 7th December 2019, 02:54 PM
Is it possible that your gearstick movements merely coincided with the intermittency of the fault? I've had starter motor faults that resulted in similar, seemingly random behaviour.
Old 7th December 2019, 04:33 PM
I don't think so, I had the key twisted into start position and held it there with no "click" of the relay.
As soon as I moved the stick it started.
Old 7th December 2019, 06:42 PM
B@fink B@fink is offline
If the F125 checks out, have you checked the main battery cable on the drivers side chassis? When that corrodes out you have power to everything but no starter action. If it’s getting crusty (damp and salt won’t be helping at the moment) it might start causing intermittent no start?
Old 10th December 2019, 09:45 AM
Attached is a photo of the inside of my old F125 which I decided to look at after thinking about your comment MJ.
I'm guessing that the top 4 contacts are 2 separate circuits for P/N and R and the lower 5 contacts signal what gear has been selected.
Not sure how Tiptronic works, when the lever is moved across in drive does the F125 move or not?
From the shape of the metal arcs it looks like the top one is for Park and Neutral with the second completing the circuit and the third/fourth for Reverse.
So, hopefully if there's damaged contact on the P/N circuit (it is currently working in P so not broken off) it may not affect other functions. Fingers crossed.
I also noticed that the Reverse contact points on the embedded metal strips are discoloured, especially the small one. Awful design!
From what I know of the wiring that's probably taking all the current to the reversing lights when they are on, so is almost certainly the most heavily loaded area for a significant time.
The P/N contacts are only briefly operating a relay during starting (NOT the starter solenoid!) and the set of 5 are probably just small electronic signals.
