Old 6th November 2016, 12:03 PM
You sure its ABZ, VAS-PC has no ABZ listed for any era of A8
Old 6th November 2016, 01:29 PM
Just checked on my AHC and it shows' Label file: REDIR FAIL' and cannot find label file related to ECU but it still shows values as it should.
Old 6th November 2016, 03:30 PM
Yeah thats what it does for us ^ It shows the values fine, but with no clue as to their meaning Tricky to fault-find when you don't know what everything means.
Del - definitely ABZ. Thats the default 4.2 32V coilpack motor that PF 8's got.
Maybe I'll write a label file then.
Old 6th November 2016, 06:39 PM
Red face
100%
I'm assuming the miss continues after reset with vcds. If it wasn't throwing pas fluid out as quick as I could put it in I'd have given it a good run.
Could be stale fuel anars, should be able to smell that from the filler, and prolly over half a tank of it in there. Not 3 years old though maybe 2.
WD40 will be your friend for sure.
I couldn't kill it by using it I'm sure it's not dead buy parking it up. She's a trojan I tell you
Old 12th August 2018, 12:57 AM
quattrofrank quattrofrank is offline
Did any one make this label file?
Trying to fix my throttle adjustment vcds show only 75% even when full throttle. But its kinda hard to find the adaption adjustment without all the labels
