Old 13th August 2018, 05:13 PM
AndyC AndyC is offline
Default S8 inlet noise
Both s8s I have tested have this rattle from the inlet manifold at part throttle
Is this normal?
Old 13th August 2018, 09:49 PM
Norretal's Avatar
Norretal Norretal is offline
Both have fairly high mileage?
Audi TT - 2015 - Ultra
Old 13th August 2018, 11:00 PM
Its likely rattling because the flaps are broken, a new manifold is around 2k so you could use that as bargaining power but its also with some risk as the broken parts could go down into the valves.
But if it hasn't you can remove the manifold and gutt the internals out and reassemble
Old 13th August 2018, 11:11 PM
78k and 120k... the 120k has full audi history and is extremely tidy... offered 8k for it... accepted.
Drives well enough..
Just inlet and dampers really
