Old 12th June 2018, 01:34 PM
Regulus Regulus is offline
I have started to take the door appart.
The window regulator is riveted to the door, uh uh.
Will have to go and buy a rivet tool.
The bird **** is a gift from the birds at Durker Roods
ID:	19481   Click image for larger version
ID:	19482   Click image for larger version
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 12th June 2018, 06:07 PM
The window has two guides that runs in the rails, one on each side.
There are 6 rivets holding the window regulator.
I doubt I followed the correct procedure while dismantling everything.
ID:	19485   Click image for larger version
ID:	19486   Click image for larger version
Johannes
_________
A8 32V engine
Old 14th June 2018, 06:23 PM
So, I finally managed to get the door back in place.
The wire from the inner door handle to the lock gave me a hard time.
I tried to fit the wire back on while holding the window. Turned out to be impossible for me. So I had to take the wire out and then refit it to the lock mechanism.
In hindsight, I believe it would have been a lot easier to remove the wire from the window part, and leave it connected to the door lock.
ID:	19521   Click image for larger version
ID:	19522   Click image for larger version
Johannes
_________
A8 32V engine
Old 15th June 2018, 08:32 AM
Zip's Avatar
Zip Zip is offline
Thumbs up
I replaced a mechanism years ago on one of mine. I drilled out the rivets, swapped over a good one from a donor, and used nilock nuts and bolts in place of rivets. Haven't had to touch it since.
Regards,
Zip
