Old 22nd June 2018, 10:44 PM
Chip2786 Chip2786 is offline
Default Just Fitted a Fire TV On MMI 2G
I had a spare input on my digital tuner so I thought I’d stick at Fire TV in it. It works amazingly and now I have built in Netflix, Kodi, Apple Music, iPlayer etc. On all 3 TV’s Proper chuffed with it.
Here’s what I needed;
AV in cable
https://rover.ebay.com/rover/0/0/0?m...2F381575113139
4G Router and SIM card
Huawei E5577 Black 4G Low-cost Travel Wi-Fi, Super-Fast Portable Mobile Wi-Fi Hotspot – Long-lasting Battery
https://www.amazon.co.uk/dp/B011YM0O..._vTxlBbDCR7CJA
HDMI to Composite adapter (I had one of these in stock but this should do)
https://www.amazon.co.uk/dp/B01N5KNF..._EXxlBb4MGJPCF
And 2 of these 12v to 5v converters
https://www.amazon.co.uk/dp/B00G890M..._L2xlBbMZYJ8R9
ID:	19598   Click image for larger version
ID:	19599   Click image for larger version
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 22nd June 2018, 10:45 PM
No idea why 2 of the pictures are upside down
Jobs done so far;
Old 23rd June 2018, 12:37 AM
H-M3 H-M3 is offline
That’s cool any chance of getting some wiring pics? I have 3 of those cables not sure what colour pins go where on the dtv
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 23rd June 2018, 12:31 PM
Sure, next time I have the DTV unit out I’ll get some pics.
If you have a continuity tester it’s easy enough to figure out which pin does what, then you just use the attached pin outs on the DTV plug
Jobs done so far;
Old 24th June 2018, 09:35 PM
Hello Chip, I like what you have done.
Do you have any audio whine/hum whistle (ground loop feedback).
I do and I'm using a bluetooth receiver on AV1 and a MOTOVIEW airplay/chromecast on AV2 and was wondering if your power supply would be better than my USB cigar adapter.
Old 25th June 2018, 03:51 AM
There is a slight high pitched hum when no audio is playing but it’s not Audiable when something is
Doesn’t the cig socket stay powered all the time?
If you are getting a ground loop you could try this?
https://rover.ebay.com/rover/0/0/0?m...2F250489744414
Jobs done so far;
Old 25th June 2018, 08:31 AM
Thanks.
Yes cig socket is on all the time, but battery seems to cope OK. I would unplug if I was parked at the airport etc... but car is used at least 5 times a week.
I will make a switched supply one day as per the video on dognmonkey.com website.
I might try one of those isolators but in theory, they should reduce the audio quality a bit. I'll post back if/when i do.
Old 25th June 2018, 09:07 AM
Thanks.
I will make a switched supply one day as per the video on dog n monkey website.
My car came with a PS2 fitted so I already had these piggy-back fuses installed, one is constant 12v and the other is ignition
Not sure why they ran the constant all the way through the car though
Jobs done so far;
Old 28th June 2018, 08:12 PM
I bought 2 of the ones listed above and it makes a MASSIVE difference, no loss of signal quality but when the music is paused now I hear nothing! Sounds so frikken good now! Highly recommend
Jobs done so far;
Old 6th July 2018, 04:44 PM
I got bored of the Fire TV so I swapped it for an Apple TV, much better airplay support and still has all my favourite apps.
Instead of getting a (big nasty) power inverter I opened the Apple TV up and found that the Transformer outputs 3.3v so I bought a 12-4v in-line step down tranny and it runs it fine. Now I get the Album/Track/Art Show on my MMI screen whilst airplaying
ID:	19663   Click image for larger version
Jobs done so far;
