Old 9th June 2018, 01:53 PM
Regulus Regulus is offline
Default Window regulator failure
I am in the process of trying to repair the left rear window. First I looked at the switch, as I hoped I might not have to pull the panel off.
Taking the panel off, I immediately noticed a piece at the bottom of the door.
After further inspection, the window regulator mechanism is clearly broken.
Any chance I can get it back together to be able to fully close the window?
edit: (I just remembered it is vacuum driven) HPsauce is correct, my mistake.
ID:	19427   Click image for larger version
ID:	19428   Click image for larger version
ID:	19429   Click image for larger version
ID:	19430   Click image for larger version
ID:	19431   Click image for larger version
Name:	Window regulator rear left.png
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 9th June 2018, 02:00 PM
I thought the window mechanism was driven by an electric motor? The central locking is a vacuum/pump system.
Hopefully someone will be along soon who recognises those broken components.
Old 9th June 2018, 02:05 PM
You are right. When I try to hold it together by hand, I see the wire moving in the low left side. Behind that L-shaped arm. The window is moving slightly. Either up or down.
Johannes
_________
A8 32V engine
Old 9th June 2018, 02:18 PM
The wire is broken
Johannes
_________
A8 32V engine
Old 9th June 2018, 02:33 PM
Pretty common for the wire to get rusty and snap. You'll need the regulator mechanism per your last picture.
Old 9th June 2018, 02:44 PM
Yes. I think I will need the regulator for both rear sides. As the right one has been tricky as well, although it isn't as bad as this side.
Well, now I at least know what and where the problem is
Johannes
_________
A8 32V engine
Old 9th June 2018, 04:12 PM
It is easy to remove the door panel.
I removed the two philips screws with washers along with the 8 mm bolt. Then the door switch panel was removed. Two small philips screws up in each top corner of the door.
Then 3 larger philips screws under the plastic trim.
I did break one plastic plug though, taking the whole panel loose.
Last part was to release the wire going to the door handle inside.
ID:	19434   Click image for larger version
Johannes
_________
A8 32V engine
Old 9th June 2018, 04:17 PM
I think it's assumed you will always break some of the plastic clips. Our sponsors tend to include a handful automatically with any parts that are likely to require removing a door trim.
Old 9th June 2018, 04:18 PM
You did well to only break one clip - usually most of them break. I replace all of them when the door card comes off since they usually don't go back together again.
The number is 4D0 867 299D
Old 9th June 2018, 05:17 PM
Brilliant, thank you for the part number
Johannes
_________
A8 32V engine
