Old 17th April 2018, 10:58 AM
ulfilias ulfilias is offline
Default Vag Can Pro
Hi There,
Picked up a version off ebay as at £14 it was worth looking at
https://www.ebay.co.uk/itm/VAG-PRO-C...e/382415502595
It's obviously an older copied version running at 5.51 and i also found a get rid on the dongle completely patch off the net which replaces a couple of files.
It's a stand alone install that you can just un-rar the software and run.
I was worried i'd need to get my old net-top out but it seems to run fine on Windows 10.
It can do a similar scan to VCDS and ODB11 which is useful and seems to have some different functions, including flashing things which i've heard can be dangerous, so i've not played with them
Another tool to my arsenal, if needed!
Lee
Ooops. VAG CAN PRO....not com....can't seem to edit the title!
Current :
Previous :
Also :
Last edited by Architex_mA8tey; 18th April 2018 at 12:12 PM. Reason: correct title
Old 18th April 2018, 12:13 PM
Corrected
