Old 9th September 2012, 07:20 PM
mannyo mannyo is offline
Default RNS-D and TMC retrofit 2001 FL 3.7
Thanks to Ranj, I now have in my possession an RNS-D satnav unit and TMC module.
I believe the car the rns-d was removed from has Bose, as do I so the coding of the headunit using VCDS should be correct already.
Whilst I can probably get my head around the connection on the back of the RNS-D (assuming its a straight swap for my double din Symphony) the TMC module is a whole new kettle of fish.
I have located a cable set on ebay
http://www.ebay.co.uk/itm/1207551036...ht_2283wt_1168
looks like the right sort of thing, hopefully it comes with instructions, but apart from the aerial cables I am not sure how the other wires will connect and to where?.
Manny
Past
Old 9th September 2012, 08:38 PM
Reffro Reffro is offline
My old car did have Bose, so hopefully that's unit you chose.
Old 9th September 2012, 08:41 PM
Yep, I have the one that was in your old car.
Manny
Past
Old 10th September 2012, 07:45 AM
That cable will get the TMC working (and thus put the Radio/Satnav info on the DIS), and is an easy install. Power, ground, canbus pair to car and canbus pair to Nav unit.
You will also need something like this:
http://www.ebay.co.uk/itm/Plug-Play-...06%26rk%3D1%26
To give you the extra connector that plugs into the RNS-D.
Also - If you have symphony 2, I'm 99.999% sure it doesnt have a GALA feed into it, and the Sat Nav absolutely needs one, so you will need to tap that off the back of the instrument cluster where it is generated.
Other than that, it should be pretty straightforward
Old 10th September 2012, 02:31 PM
I have ordered both cables, that's the plug and play harness, and the TMC wiring cable I linked to, also ordered a hockey puck GPS receiver and some radio removal keys.
I guess I only need the additional connector from the plug and play loom to connect the can signals to from the TMC?
I have a Symphony MK1, and looking at the pinout diagram I found on the internet it has a Gala input. Hopefully the wire will be present in the existing connector, otherwise I'll get one from the cluster whilst its out.
Manny
Past
Old 12th September 2012, 10:56 AM
All the wiring has now been delivered.
Need some hints with the TMC kit though as it has no instructions. The grey wires have the pins that look like they simply plug into the appropriate pins on the back of the RNS-D. (Can-H and Can-L). Red and Brown, I think are power (+ red and - Brown), but then I have two other cables Orange/Purple and Orange Brown which I assume are for the cluster end. They have supplied Scotch lock connectors, but which wires on the back of the cluster do I patch into.
Manny
Past
